Question about Kenmore 98702 Stacked Washer/Dryer
Washer will not go through spin cycle
I have a Kennmore stacked washer and dryer model number 98012/90817. The machine goes through the wash cycle just fine but stops at the spin cyle. It agitates properly while in the wash cycle but does nothing in the spin cycle. I have tried putting the machine on different settings and moving the tub around but nothing I do seems to help. Is there anything I can do to fix the problem?
  • 481 Answers
It sounds like it could be the lid switch malfunctioning. the part should look something like this. Washer will not go through spin cycle - d668319.jpg
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 29, 2008
Frigidaire FEX831CS Top Load Stacked Washer / Dryer will not spin - burn smell
The transmission is burnt out. Happened to my mother in law a few months ago.
Nov 13, 2011 | Frigidaire FEX831CS Top Load Stacked...
We installed a stacked set of WFW9250WW and WGD9270XW Whirlpool washer and dryer. When we turned on the washer, everything worked fine until the spin cycle. The machine started vibrating violently and...
Hello, welcome to FixYa.
I understand you have a problem with your stacked washer & dryer, thank you for providing the model number (of both) that is a good start... however I need to follow that up with a couple of questions.
Are these "new to you" machines or have you had them prior to this and just never stacked ?
Also had you run the washer before they where stacked and not noticed an vibrations violently/noise like a hammer spinning inside?
Finally, what method did you use to fasten the dryer to the top of the washer and did you remove the cabinet top of the washer before stacking...for the record it should not be removed as was the case with some other manufactured machines.
Let me know if you can add anything further along with the make & model. I will wait for your reply to move forward.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Jul 13, 2011 | Whirlpool Washing Machines
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Washer fills during spin cycle
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Feb 12, 2009 | Whirlpool LTE5243D Top Load Stacked...
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
166 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
