Question about Matsonic MS9158E+ Motherboard
Hi can you help me plz
I am haveing great problems with my motherboard...i am trying to put the leads back on so it powers up (ie) ground leads power cable lead can you please try to help me.....
manythanks
  • 84 Answers
Your motherboard manual will give you that infromation .
If you can tell me what make and model of motherboard I can send you link for manual .
Posted on Jul 29, 2008
POWER UP AND IMMEDIATELY POWERS DOWN PC WORLD SUGGEST THIS IS A BLOWN MOTHERBOARD HOW MUCH IS A FIT MYSELF NEW MOTHERBOARD
This could be a power supply fault,check the volts on the red,yellow and earth lead(black)THE RED LEAD =5VOLTS
YELLOW LEAD=12VOLTS.WHITE=-5VOLTS
BLUE=-12VOLTS,PURPLE,=+3.3VOLTS
BROWN=+5VOLTS VSB
BLACK=GROUND.
Diconnect the pc mains plug from the computer.
Disconnect the power supply leads from the motherboard,and switch on and check the volts on all leads of all those I mentioned.If these are present when they are not connected to the main board,then the problem is with the motherborad,most likely the bios chip is faulty.This chip kicks starts the PC into coming on.Failing this send the PC back to where you bought it and let them fix it.
IT COULD ALSO BE THE MAIN ON OFF SWITCH AND THE CABLE ITSELF FAILING.CHECK THIS WITH AN OHM METER ON X1 OF THE RESISTANCE SCALE.DISCONNECT THE MAINS PLUG FIRST.
Aug 07, 2010 | HP Compaq Presario F500 F700 and G6000...
My light wont come on period.
the remote needs to be plugged in as well. it should be next to the power/ground terminals. put 12volts on it. lights should come on. if not amp is faulty.
Sep 07, 2009 | Pioneer GM-5200T Car Audio Amplifier
What makes a nitro 1200 watt amp go to protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. makes-nitro-1200-watt-amp-go-protect-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Aug 02, 2009 | Nitro BMW-482 Car Audio Amplifier
Finding it hard to put leads back on to motherboard to boot up
From the motherboard number you gave, I think it's made by ECS. Take a look at the picture on this page at the ECS site and see if it looks like your board:
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=530&DetailName=Feature&MenuID=52&LanID=0
If it's the one you have, you can download the manual just by clicking the link below the picture. You can also get any other information and driver updates that you might need.
Please take a moment to give this solution a good rating if it's been helpful.
Mar 02, 2009 | Computers & Internet
Pc restarts & display "System has recovered from serious error"
If you have *********** board manual still then try and clear the CMOS memory,
turn the computer off
remove the power lead from the back
take the side off
remove the cmos battery
move the cmos jumper from pins 1 and 2 to pin 2 and 3 and the back to pins 1 and 2
replace the battery
put the side on
replug in the power lead
boot the computer
if that doesn't work then try to fix the bios.
here are instructions for that:
http://support.intel.com/support/motherboards/desktop/sb/CS-023360.htm
and here is a link to the .bio file for you:
http://downloadcenter.intel.com/download.aspx?url=/10140/eng/EV0482P.BIO&DwnldId=10140&ProductID=1673&lang=eng
Feb 18, 2009 | Intel D915GAV Motherboard
KM18G pro motherboard power connection, reset sw, power sw, etc.
Hi.
You can download the manual for your motherboard here.
Inside you will find information of where does each connector go. Each connector on the case has a marking on it (HDD, PWR, RST or similar) which stands for hard disk LED, power button, reset button and so on. Connect it to the right place, and problem is solved.
If you need any further assistance, feel free to ask.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 18, 2009 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
Won't tune on.
sounds like a motherboard problem if a using a different battery and power adapter did not fix it. Though, you may want to reseat the memory modules, or if available, swap them with known-good memory modules just to isolate that the problem is not memory related.
Dec 21, 2008 | HP Compaq nx6110 PC Laptop
try this site its matsonic but does noy list your board number it lists 9300 series maybe one of them will contain info to setup the leads on yours it is a pdf download
Jul 29, 2008 | Matsonic MS9158E+ Motherboard
No power to my legacy 600 watt car amp
Hmm...ive had this problem before and its always been either the remote wire, the rca cables or the ground. i would try hooking up the remote wire strait to the battery, if that doesnt work try to find a better place for the ground. maybe where your trunk latches. if that still doesnt work then i would try new rca cables.
Feb 13, 2008 | Car Audio & Video
Computer doesn't switch on!
More than likely nothing to do with the motherboard.
I have the Thermaltake w0049. and for the money paid is poor quality.
This model and I would guess other models by Thermaltake go belly up if subjected to voltage spikes ie lightening strikes (they are not well protected)
Remove all the leads to your motherboard and join together the single green wire (power select) to any one of the adjacent black leads (ground).
Any atx supply, if connected to mains voltage will not operate at all unless if has some form of load on it. if you do the shunt as suggested(use a paper clip) the fans should spin and you should be able to measure the voltages between ground and the relevant pins.
If you can, plug in a hdd to one of the plugs to give it some kind of load. if you do not know which voltage pins are which on your 20/24 pin connector , then search google for "atx pinout"
Dec 21, 2007 | Computers & Internet
Matsonic MS9158E+ Motherboard Logo
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
