CRANK SHAFT PULLEY BOLT TORQUE IS 83 FT LBS. MAIN BEARINGS TORQUE IS 48 FT LBS ROD BEARINGS TORQUE 23 FT LBS. YOU NEED A BEARING SEQUENCE GET PIECE OF PAPER WRITE NUMBERS 9 5 1 3 7 AND UNDER THIS NUMBER LINE NUMBERS UP ON EACH OTHER WRITE DOWN NUMBERS 8 6 2 4 10 YOU HAVE 10 CRANKSHAFT MAIN BEARING BOLTS. WHEN YOU LINE UP BOTH NUMBERS YOU WILL START TIGHTEN BOLTS 1 AND 2 TIGHTEN BOLTS 3 AND 4 TIGHTEN BOLTS 5 AND 6 TIGHTEN BOLTS 7 AND 8 TIGHTEN BOLTS 9 AND 10 YOU ARE TIGHTEN BOLTS IN A CRISS CROSS PATTERN. BESURE TO POUR OIL OR LUBRICATE CRANKSHAFT AND BEARINGS WITH CLEAN ENGINE OIL.WHEN YOU TORQUE MAIN BEARINGS TORQUE ALL THEM TO 20 FT LBS AND SECOND PASS TORQUE ALL BOLTS TO FINAL TORQUE 48 FT LBS. IF YOU RUN TO ANY PROBLEMS. YOU CAN BUY A HAYNES REPAIR MANUAL IT CAN HELP YOU.
