I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
  • govegan Aug 22, 2008
    I have the same problem. Brand new machine. Sometimes it spins, most times it doesn't. An engineer is coming out during the week to take a look. Did you find out what was wrong with yours?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Posted on Jun 13, 2009
Hi, our same machine is getting the same "UNB END" error and not spinning.
Unfortunately Bull's error codes don't seem to cover this - did anybody find out where the problem with the spin cycle comes from/how it can be fixed?
Cheers,
Andy
Posted on Jan 17, 2010
  • andyt1000 Jan 17, 2010
    I'm such a plumb at times!!!
    "UNB" stands for Unbalanced - have wriggled the machine around and put it on another spin cycle, and am waiting the results now. It sounds better already though so fingers crossed!
    No luck, still not working :(
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
Hi my washing machine wont stop running when the cycle ends - I have to pull the plub at the mains
Reason for taking a long time spinning is that it might have an uneven load. The wrong number of bath towels, for instance will mean it takes 3 or 4 tries at getting the spin right before it can spin them at the correct speed. An unbalanced load doesn't do the machine any good either.
After this wash has finished try it on something a lot lighter- say a duvet cover only with a couple of pillowcases. If that takes a long time too then the trouble is with the machine.
Looks like your "programmer" has stopped on the "spin cycle".
Could be a sensor has gone.
But everything points to the "little drive" in the programmer.
You could try "Manually Rotating The Selector Round a Few Times"
(This could free something off)
If a new "programmer" is needed, This could be more expensive than a new machine.
If the machine is under a year old it will still be under guarantee. If it is slightly over the year, but under 18 months old you still have a good case to go back to the manufacturer and get them to fix it.
Jul 03, 2009 | Hotpoint Washing Machines
Washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Apr 10, 2009 | Haier Washing Machines
Front loading Haier HW-D1470TVE Door will not open. This inspite of the wash programme having ran and the digital dispkay reads "end". What can I do?
Sounds like your door is locked. Unplug the unit for 30 minutes then plug it back it hopefully it will reset everything and you will be able to open the door. Then after you get the door open you will need to run some tests to see what is the problem. Check the door lock sensor and the door lock mechanism
Feb 19, 2009 | Haier XQG50-11 Front Load Washer / Dryer
Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Feb 17, 2009 | Haier HWD1000
HAIER HW-C1460TVEME-U
Err1 : Door not properly shut
Err2 : Drainage error (clean filter check hose
Err3 : temperature sensor short circuit
Err4 : Heater error
Err5 : water fails to meet specified level within 8 mins check tap, water pressure
Err6 : motor error
Err7 : motor error
Err8 : water exceeds protective level check circuit
End : end of wash cycle
Unb : after the last rinsing cycle finishes spinning fails completelt due to unbalance of the laundry
only reason I know is i looked through the manual after getting it myself could be something to do with running a bath while washer on or something perhaps not enough water getting in if powder channel blocked
Sep 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
1,032 people viewed this question
Top Washing Machines Experts
