Question about Dynex DX-E401 Router
Wired dynex router suddenly started interfering with my internet connection.
I had been using my router for about 2-3 years with no problem, and then it would not let me have any internet connection until it was taken out of the system. Model NO. DX-E401 Serial No. ZB0 1A58002867
    Scholar:
  • 87 Answers
Verify your router is connected to a standard grounded outlet. Check that the Internet cable is connected to the WAN port on your router, and check the WAN light on the front of your router is illuminated. Check that the LAN lights are on.
Power cycle your router by unplugging the DSL/Cable Modem from the power, then unplug the router and power off your computers. Then, plug in the DSL/Cable Modem to the wall and wait until all the lights are on and none of them are blinking. Power on the DX-E401 router and wait until all the lights are on. Now, power on one computer and verify the Internet connection.
You can verify your router is working properly by sending an echo request to it and verifying the response you get.
If you are a Windows user go to Start, select the Run option and in the dialog box type in CMD. Once there, type in ping 192.168.0.1 and you should get 0% loss as a response.
If these do not help, the router is likely to have malfunctioned, requiring repair or replacement.
Posted on Oct 21, 2008
Was working on my laptop upstairs and it told me I lost my internet connection. The IP address was192.168.2.1. Now all of a sudden can't assess my network from any wireless device. When I type in...
1. First thing you should do is RESET (both) the router and modem.
2. Check if the wireless and wired connections are ok.
3. Contact your ISP, let them check your status.
Jul 03, 2011 | Dynex DXWEGRTR Router
I have a dynex 8 port gigabit ethernet switch. I see 8 ports but do not see a port to put the incoming ethernet wire. I put it in port 1 and put an outbound in port 2 but cannot connect to the internet.
Hello
Connections should go.Main internet to router,then from router to dynex switch,then to pc or pcs.
There is no main internet ethernet port, as this is just a switch.You need a Router before the dynex switch.
http://dynexproducts.com/cms/documents/DX-GB8PRT_10-1124_QSG_V1_ENG_Final%20Press.pdf
Apr 08, 2011 | Dynex Computers & Internet
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
Router stopped working
check the power adopter and and also check your router's power led is glowing or not, if both are ok then need to check your internet service provider about internet connection.
Mar 04, 2010 | Dynex Enhanced-G Wireless Broadband Router
Dynex router won't communicate with the modem.
If you connect the modem to the computer, does it go online ?
If your computer is online through the modem, then the modem is working properly.
Check the connections between the modem and the router.
Reset the router for 30 seconds , unplug the power to the router and plug it back in. Wait for 1 minute and set up the router again manually.
Click Here for more info
Nov 12, 2009 | Dynex DX-E401 Router
Cannot connect to internet using Dynex Wired Router
First, power down all equipment.
Second, plug in power to modem, let all the lights come on and boot up
Third, plug in the router power and let that boot up and the lights come on
Fourth, Plug in each pc to the ports labeled 1-4
The WAN port should be connected to the Modem also.
Mar 19, 2009 | Dynex 4-Port Ethernet Broadband Router...
No Connecton with wireless computer
it just means tat the connection is secure
wat you could try would be
1) take out power for modem then dynex router
2) power the modem n then router
3) if this doesnt work you would have to redo the wireless setting on the computer
Dec 23, 2008 | Linksys Wireless-G WRT54GS Router...
Playstation 2 not connecting to the internet
the router you are using is not comp with the ps2 try using linksys or belkin
Nov 30, 2008 | Dynex DX-ESW8
Establishing a Network Connection
First whether the connection is pinging or not if pinging means its working may be the ip address problem
Feb 14, 2008 | Computers & Internet
No connection
Try resetting the router to factory , should have a button on the back to do this .
you will have to log back into it with the default factory password
see their site for more info.
Jan 26, 2008 | Dynex DX-E401 Router
Computers & Internet Logo
125 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
