Question about Dell Axim X5 Pocket PC
Sdio Wireless Lan Card Wlan 802.11b
We are having trouble inserting the card. Does the blank plastic insert go in with the card? Without the black insert the card moves around inside the slot. The blank plastic insert is a little over 1 1/2 inches wide and the lan card is less than 1 inch. Our manual with the Axim X5 says line up the lan card under the tab of the blank card and slide into slot. Help us if you can. Thanks in advance.
  • 35 Answers
The blank plastic is NOT to be used while other cards. I am assuming you are talking about the SD card slot on the side (black plastic filler) There should be no movement of the SD card when in place.
If you are talking about the CF card slot on the top of the Axim, again the blank plastic is a dust cover when no card is in place and is not used with cards inserted. There is a bit of open area on one side of the card. Carefull with the pins at the bottom and be sure to insert correctly. Again there should be no movement of the card once inserted fully.
Don't know what you are quoting from the manual. I still have mine and the only thing I see similar to your quote is to "align the tab on the back of the CF card with the notch in the CF slot.." This is to make sure you have the front and back correct and for removal of the card (by grasping the ridge/tab)
Posted on Aug 05, 2008
  • TermiteHunt Aug 05, 2008
    The Axim is NOT sdio compliant. The standard SD card is fine.
Screen goes blank when watching videos streamed from the internet
Sounds like your WLAN card this type of problem is common in HP and Dell. Try inserting a wireless USB card and intall the drivers for it. Disable your WLAN built in card by going to network connectins right click on the connection and choose disable. Run the USB card when streaming video from the internet. If the problem is corrected then the issue is for certain your WLAN card. @ that point replacing the WLAN card is optional. The USB card has better range anyway.
Hope this helps and please don't forgetr to rate. Have a great day!
Jun 03, 2011 | Computers & Internet
How do I set-up my WLAN card to my HP iPAQ Hw6515
The HP IPAQ 6515 will support WLAN access via a SDIO WIFI card (which looks like a 'long' standard SD card): it is just a bit tricky to get this add-onl SDIO WIFI card to work properly!
For more deatils and confirmation, please google:
Sep 29, 2009 | HP iPAQ hw6515 Pocket PC
Wm6can not find wlan card
type in your wlan card moddel into google and type driver at the end.
Sep 08, 2009 | Spectec SDW-822 WiFi 802.11b MiniSD Mini...
My inspiron 1501 informed me that the WLAN IEEE 802.11 WAS MALFUNCTIONING.WHAT TO DO?
The WLAN may be faulty or the driver got corrupted.
Reinstall the WLAN driver and check the Device Manager to see it the WLAN is working and enabled, if it is then configure it to match your wireless router settings.
If this doesn't work the most likely the WLAN card is faulty.
To get a wireless connection again, purchase a PCMCIA wireless card and insert it into the PCMCAI slot, install the driver for this wireless card and configure it to match your wireless router settings.
Jul 04, 2009 | Dell Inspiron 1501 Notebook
My hdd is full and I want to record on a 16GB SD card. When I insert it and try to format it does not format and I get a message state memory card error.
few, if any, SD cards larger than 2GB are SDIO compliant. Most cameras which take SD require SDIO-compliant media. Try a branded card (eg Samsung, Kingston) which is certified SDIO media.
Jul 03, 2009 | JVC Video Cameras
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
HP Pavilion ZE5185 wireless card not accepted
your laptop has buidin wireless. you don't need a additonal wirelsss card.
that's why the laptop beeps whne you insert the wireless card.
there is a wireless on-off button—located on the right side of the front of the computer—you can connect to a wireless local area network (LAN) and access computers and other resources on the network.
Nov 26, 2008 | Computers & Internet
SD wifi
I would rather go for CF wifi card, because Panasonic doesn't states that this one has SDIO type slot. If you use CF slot you will have to find WIFI card cover - it's different one - it will allow to close top cover with the card inside.
There was also two models:
  • CF-P1P1CDZ6J - Bluetooth / wireless LAN built-in
  • CF-P1P1CZZ6J - Built-in wireless LAN-model
Apr 28, 2008 | Panasonic Toughbook CF-P1
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Toshiba e355. Wireless?
"Certain Pocket PC Models have SD or SDIO slots but are not compatible with the SDIO WLAN Card. These include: Toshiba e350 and e750 – these have SDIO slots but do not have SDIO Now! software from BSQUARE. The e355 is the same as the e350.
Sep 11, 2005 | Toshiba e355 Pocket PC
Dell Axim X5 Pocket PC Logo
197 people viewed this question
Alun Cox
