Question about E-Machines eMachines Desktop PC
2 year old E machine
Working OK then powered off, went to power on and nothing, no fan, disk, nothing... Actually went and got similar emachine, working unit, switched power supplies, would not power up, nothing... tried woking machine with power supply from the one that had failed, testing to see if the power supply was the problem, good machine would not power up and now with good supply in good emachine, it's not working... So, there you go, both emachines now not working... Any thoughts... Thanks Mz
  • adam_tremain Jan 08, 2009
    I have the same problem on an older machine, 2862t. The only thing I can think of is the power switch on the front of the machine is faulty.
  • california2d Feb 01, 2009
    Help...
    My emachine also would not turn on at all one day..put in new power supply and still nothing...put in new motherboard and still nothing...couild it be the pushbutton on the front?? Where can I get one of these pushbuttons? E-machines doesnt sell them seperately either!!
    dave
    Problem Solver:
  • 44 Answers
Dear zmatt,
Looks like the power outlet or UPS may be at fault. Try a different outlet. That's all I can thik of.
Posted on Aug 01, 2008
I have a ET1331G-03W Emachine and this morning it was working and then it just shut down. When I went to start it again using the eluminated front button it came on for a second and then off. I unplugged...
emachine ! ( junk) sorry but sounds like the mother board died on ya time for a new one bro this is a hardware problem and emachines tend to do this after a year or two and if they don't get good air flow they get hot and fry out thats what it sounds like the mom board went out so don't waste your time trying to fix will end up costing you more to have someone do it right and will probably get ripped off in the process unless you know how to. so buy a new one the best desk tops are HP, toshiba, and get a higher end one if ya can sorry but is a spendy problem good luck and have a nice day the fixist
Jul 07, 2010 | E-Machines eMachines Desktop PC
Power went off while downloading something
ok check in the back of the computer and see if the fan is coming on when you press the power button on the computer. if fan is not coming on then you need to replace the power supply that has the fan on it. this cause the computer to shut off and stay off. if the fan is working then use the system recovery disk to do a factory reset. put the disk in the drive and turn the computer on while holding down F1 or F2. then you will be taken to the windows screen. follow instructions from there and you will be fine
Jun 05, 2009 | E-Machines eMachines Desktop PC
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
Won't power up
Did you install correctly the cables?
Did you move any card or memory?
Check it out again!!
The fan of the motherboard is working?
Hit the reset buttom and see what happen
If doesn't work is a bad motherboard
Oct 03, 2008 | E-Machines eMachines Desktop PC
Emachine 5210
Emachines used to use a poor quality power supply made by Bestec, I believe the quality is supposed to have improved in the last few years but inconsidering the number of dead Emachines that wind up in my workshop I doubt it.
The problem you have is that being a poor quality power supply there is a very high risk that it damaged the motherboard when it went out.
If you can borrow a power supply just to test with all the beter BUT be carefull some Emachines are proprietary and the main motherboard plug is not always wired in the standard way.
Check here for a replacement power supply if you can prove your motherboard to be OK.
http://www.affordablesurplus.com/
Have a look on this site for examples of standard and proprietary power supply wiring colours.
http://pinouts.ru/pin_Power.shtml
Aug 21, 2008 | E-Machines eMachines Desktop PC
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
T2085 will not turn on
it does sound like a power supply. you can pick one up for around 80 bucks retail. they aren't that hard to install. 2 plugs on the mobo and one for each drive you have installed. all you do is unscrew the current power supply (4 screws on the back), then unplug all wires connecting the power supply to the components. then take out the old power supply and work in reverse with the new power supply.
if the computer doesn't work after that, it is possible that you need a new mother board. in that case, personally i would return the power supply and start looking for another computer.
but hopefully it is just the power supply.
Agent 10708
May 29, 2008 | E-Machines eMachines Desktop PC
Emachine 5210 not working
how old is your emachine?? is your display in condition?? if so, your smps might've worn out.. this is what happens when the display is proper but u still don see anything on the screen..
Mar 12, 2008 | E-Machines eMachines Desktop PC
First Power Saver Came Up & Now Fans Aren't Working
It is very possible that the power supply has gone out. If you hear the drives spinning up then its not. check the power supply thats what I'd do first
Dec 20, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
150 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
