Dvdrecorder and convertor box
I have regular analog tv, and i want to record it to dvd, so i bought a dvd recorder and convertor box per best buy recommendation but i cant get the dvd recorder to record. how should i be connecting these?
  • kaleidoscope May 11, 2010
    I take it the converter box just converts digital signal to analogue
    Problem Solver:
  • 12 Answers
If the clarification request is correct. The only thing i can suggest is. Plug aerial into converter box. plug converter box into TV using either scart or coaxial cable. then connect converter box to dvd recorder using scart or coaxial cable depending on what you used to plug converter box into TV with. Then plug dvd recorder into TV. I don't know if you have to set-up the converter box to start receiving i'm not sure. But try this anyway.
You'd probably have been better off getting a free-view box and your dvd recorder. Because as long as you've got a free-view box you'll always get digital. Hope this helps
Posted on Jul 29, 2008
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
No aeriel just cable tv and dvd recorder
Hi,you will need an aerial for the dvd to pick up any analog signals or freeview,but if you connect a scart lead from you cable into you dvd on av2,you will be able to record cable.You will not be able to change chans when you are recording this way.It would be best to get an aerial and a freveiw box with a hard drive.Hope this is of some help? jamie
Mar 15, 2009 | Philips Televison & Video
Vcr & dvd & a CONVERTER BOX
Right, you don't have to plug DVD/VCR to box, just straight to TV to operate. If you wanted to record hdtv programs from the box to the vcr or a dvd recorder then connect box to vcr/dvd recorder to TV.
Oct 16, 2008 | Insignia Digital-to-Analog Converter for...
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Converter box
the digital box has to hooked up the rca plugs on the bac of the vcr if you want to use the vcr (you will only be able to pick up channels throught input and the box will have be set on the channel you want to record. You need a switch to hook the vcr and dvd player both up. the atenna cord can be attached to the back of the convertor box then attached to the tv.
Jun 15, 2008 | Insignia Digital-to-Analog Converter for...
HOW DO I HOOKUP THE DVDRECORDER TO MY ALREADY CONNECTED DVD/VCR,TV,SATELITE BOX
I suggest an AUDIO/VIDEO SELECTOR BOX since your going to be using your DVD RECORDER to record from these sources. hope it helps.
Apr 21, 2008 | Televison & Video
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
