LCD tv "burn in"..
Hi there, sorry to bother you but i had a quick look at your profile and you seem to know the ins and outs of tv's. I was just wondering if you could please give me some advice on this problem i have encountered for quite a while know. Basically I used to use my tv in 4:3 aspect ratio when i was on the computer. I did not realise that after a while when i had it on the fullscreen (16:9 ratio) that there was a feint black line on the left side of the screen in the exact same place where the edge of the 4:3 aspect ratio was. If you get me there?
so far i have tried a program called JScreenFix which shows loads of pixels quickly changing colour and is supposed to sort out screen burn (which i believe to have). but nothing is working so far.
So could you please help me on this one, or should i be sending my tv back?
Thanks very much,
sean
  • sean_64 Jul 29, 2008
    Ok thanks for the help.
    I have a warranty so its all good.
    Bye
  • 8,617 Answers
There is really no way to get rid of burn in. If you can return your set I would as the only way to fix it is with a new panel which is ver exspensive.
Posted on Jul 29, 2008
What to do if you plug something in service box
Hi. sorry to hear that but you might have burned out your main board. it will need to get replaced.
You can get parts for this tv at www.interliquidparts.com
Mar 02, 2012 | Vizio VX42L 42 in. LCD TV
I have a 42" JVC LCD television that I use for
No,sorry.U can't not fixed this problems beside changing the whole tv LCD sceen panel it is not econmicial to change the tv LCD screen panel,because the LCD screen panel cost almost the as a new tv itself .This it is call "screen burn in" the image it there for good sorry.
Aug 10, 2011 | JVC LT-42X579 42 in. LCD TV
There is a brownish spot near the bottom of the screen - almost looks like a burn spot about 6" by 2.5" on my Samsung LCD 40" tv screen.
U have a burn in image to LCD screen panel like display the same image too long like hours in and out.Sorry this problems,have to live with it.Can't remove burn in images problems.
Mar 22, 2011 | Samsung LN40B530 40 in. LCD HDTV
Transmission pours fluid next to motor goes in reverse but not drive
There are two lines that run from the radiator to the transmission. Those are the cooling lines.Follow them carefully and you will find the one that's leaking. If the fluid is coming out under the car, between the trans bellhousing and engine, likely you also burned out the front pump seal. If so, don't bother replacing it without having the unit rebuilt, or replace the unit with one from a scrapyard. BUT if you were doing 100mph when the leak began, it is more than likely that you burned out the transmission. The parts in there are very sensitive to low fluid conditions and will quickly burn up the internal clutches if it is low (especially at that speed)
Sorry to have to tell you that but with transmissions, that's what happens and there aren't any easy cheap repairs.
Mar 26, 2010 | 2001 Chevrolet Monte Carlo
I have a broken LCD display on my philips 32pfl5332d, need a replacement part, please advise.
dont bother costs more than the tv/plus fitting/ take parts out sell on ebay buddy
sorry
Jan 08, 2010 | Philips 32PFL5332D 32 in. LCD Television
Tv keeps turning itself off
You most likely either have a faulty power supply or high voltage transformer that is failing. You can test them both with a voltmeter or multi-tester. The capacitors on the newer sets seem to overheat and burn out quickly
Oct 10, 2009 | Televison & Video
Hi i have a ploblem i bought this proscan lcd 19inch tv a year ago now it doest turn on
Unfortunately, many new electronics are made cheaper nowdays and the power supplys do burn out quickly. It should be tested with voltmeter to determine if it needs to be fixed or replaced. The power supplies have capacitors and resistors in them that tend to fry out.
Aug 28, 2009 | Televison & Video
Trying to connect LCD TV to laptop
you need a serial port on the tv if it doesnt have one dont bother, sorry
May 20, 2009 | Televison & Video
LCD light burned out on a 2003 4runner
I GUESS YOU COULD CALL IT A ASH TRAY BUT IT IS NOT, I KEEP RECEIPTS IN THERE
Jan 06, 2009 | 2003 Toyota 4Runner
We took out the power supply, now where can we send it for repair
my advise... if you are going to send it out for somebody to fix it, don't bother... buy one off ebay... if you have a multimeter and some soldering skills, you can fix it yourself.... let me know if i can help..
Dec 08, 2008 | Akai LCT2715 27 in. LCD Television
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
