This camera appears to support cards up to 1GB. What size is the card you are using?This camera appears to support cards up to 1GB. What size is the card you are using?
You can't post conmments that contain an email address.
Error e00100 means that the card is corrupted or formatted for another
digital camera.Format memory card and see the results,Try to format the memory card using a card reader with the PC, if error still exists then it means the memory card is electronically incompatible and won't workThe Kodak C310 uses MMC and SD cards and may be you are using SDHC memory card, In this case change the memory card, I hope problem will be solved, if error still exists then contact to Kodak Cameras service providers.
I hope this solution helps you Your token of appreciation in the form of Four thumbs and testimonial will be esteemed. THANK YOU and Keep Visiting FixYa!
if you already try to fromat the memory card into the camera and there's an error come.try to format your memory card from your computer if you have card reader.if the problem still occur you memory card have a problem and you need to buy new one.
1. Remove the memory card from your camera. 2. connect it to a computer using a compatible card reader or can directly connect to a laptop using its card reader present in the laptop. 3. Format the card from your computer and put the card back to your camera.
I hope this is helpful to you Please rate the solution provided. Thanks
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
Hi there Check to make sure the cards write protect is
off, take the card out of the camera, face the card towards you, look
for a small white tab on
the left hand side of the card, to unlock it push the tab down, it will
be at the side of the card like this . Put it back in the camera and use the menu to format the card. If the format fails then its a possibility that you will need a new card.
Insert your memory card into your computer's reader if you have one. If
not, you can purchase a multi-format USB Memory Card reader from
Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available
drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a
non-reversible process so make sure this is what you truly wanted to do
in the first place.
6
Once the process is completed, take the memory card out and insert it
into your Digital Camera or any other device. Try to browse to it to
make sure it works fine now.
this could be a help to you,first off most,cds, and memory disk,get scratched or worn out,that causes errors or corrupt file readings. so thats why it asked you to format,formating helps clean the drive up,like a tune up on and old car.and if you dont and try to put high grade gas in before the tune up your still going to have the same problem,so in saying you have to put the old one back in,format it. and then put the new one in after you completed formating the old one.good luck,hope that helped you.
