posted by msmx on Jul 29, 2008
I have a Toshiba laptop with Vista OS. When I started it this morning, it powered up, but then appeared to go into a hibernation state. The screen is black, the power button is blinking alternating between blue and amber and it won't shut down when I hold down the power button. I can't wake it up or shut it down.
Comment by msmx, posted on Jul 29, 2008
Thanks! That worked.
Best Solution
Try disconnecting power adapter and removing battery for two minutes. If the laptop still does not boot then there is an hardware problem. You can try taking out and putting back ram modules, but my suggestion is to take the laptop at a repair shop, if you cannot fix it by removing battery.
Rating Locked! (?) msmx has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for Toshiba Satellite A135 PC Notebook
Email this problem
Email this problem
Can you Help with these PC Laptops problems?
HOW TO DOWNLOAD THE INTALATION...
HL-DT-ST DVDRAMGMA-4082N ATA... Answer This...
How to Install Tiny XP in...
Eyyy.. you are the big one!!...... Answer This...
need drivers for toshiba...
hi hermit....i need the winxp... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
