Question about Zenith Televison & Video
My daughter has a Zenith portable DVD player (model DP260-N.AA1ULZW)that is not working properly. When we put a DVD in, it gives the message that there is "no disc". The disc does not appear to be spinning at all. I've tried cleaning the lens and that has not helped. Please advise us on what we can do to fix the problem.
  • 10 Answers
SOURCE: No valid disc
the codes might have got switched somehow (region codes.) go to this site follow the instructions.....I hope this helps!!!!
Posted on Jul 24, 2007
  • 790 Answers
SOURCE: "No Disc" Error
cleaned your lens with 100% cotton buds, if not work again change the laser eye. do it!!!
Posted on Sep 09, 2007
SOURCE: Emerson PDE-2717 Portable DVD Player - worked great for a few months but now just says 'Bad Disc' even when using discs that work in other players.
I had same problem, took the back cover off. two scews that are right were the ribbon connects to the read head I believe are potentiometers adjusted with eyeglass screw driver a couple attempts it worked. I also disconnected the plug for external battery and left unpluged since I don't use battery
Posted on Dec 29, 2007
SOURCE: Will not recognize dvd discs
Welcome to the sansui got ripped off club...c-104 is more common than rain in disc? thats what the unit finally displays when it has taken a thorough dump. Give your sansui to someone you don't like, and go buy a panasonic.
Posted on May 11, 2008
  • 19396 Answers
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Posted on Feb 10, 2009
Zenith portable dvd player dp260
My Portable DVD/Cd Player is DP260. When you switch on the player, the screen does not give any picture. But we can see the CD playing as I can see it is rotating. Pl. help me.
Jul 16, 2012 | Zenith Televison & Video
My daughter's portable DVD player says no disc
You need to clean the lens - use a can of compressed air and a q-tip. Rub gently, the suspension of the lens is very sensible and can be easily damaged beyond repair.
Aug 29, 2011 | Philips DCP85037 85 in Portable DVD Player
When a disc is put in it does not play, just get a "no disc" message
Try cleaning the dvd player lens with a dvd disk cleaner , if that fails then the dvd lens is faulty.
Aug 05, 2009 | Zenith ZPA-314 Portable DVD Player
ZENITH laser not working
Have U tried calling Zenith customer support? If they cannot help U, you usually can get it serviced at your local Radio Shack, although they may charge a lot, possibly as much as your unit is worth. You might want to google the laser lens and then see if you can get a replacement part, and then pay your local service center to put it in for U.
May 01, 2009 | Zenith DVP615 Portable DVD Player
My new zenith dvp615 portable dvd player worked 1 time & now it says there is NO DISC when infact there is a disc in the unit!! please help me fix this!!!
You should try to take this unit back to place of purchase and get an exchange.The zenith customer support telephone number is 1-800-243-4994. call them and give them the model number of your dvd player and the problem you are having with it .They will help you get the dvd player serviced or replaced.I hope this information helps you with your problem
Mar 04, 2009 | Zenith DVP615 Portable DVD Player
My portable DvD player is slowing
This dvd player is having a problem with the motor drive circuit. Either the motor is going bad or the drive circuit that supplies the power is failing.The unit need to be taken into a service center for testing and service. The Zenith customer support telephone number is 1-800-243-0000. Give them a call and they can tell you where you can take the unit for servicing. I hope this information will help you with your problem.
Feb 26, 2009 | Zenith DVP615 Portable DVD Player
AV Out cable for portable Zenith (DVP-615) dvd.
I lost the AV cord to my Zenith DVP-615 portable DVD player too. I bought a standard RCA AV but it did not work. I found my cord so I was able to compare.
The standard RCA AV cable has a 4-part mini-plug. The tip is white, next is yellow, next is ground and the base is red. For the Zenith DVP-615, the tip is yellow, next is white, next is red and the base is ground.I never found where to purchase a replacement but perhaps this will help someone make their own.
Jul 15, 2008 | Zenith DVP615 Portable DVD Player
Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
May 01, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Televison & Video Logo
210 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
