Question about Tao XM2go Satellite Radio Receiver
Tao won't start
My XM Tao (I think it's the original one) has been plugged into the wall playing in the kitchen for a few years. It suddenly went off, and will not power up.
I tried plugging it into a different wall socket. What else can I try?
Thanks!
  • Anonymous Apr 26, 2009
    Same thing happened to me as well. It suddenly turned off during operation and won't turn back on again. Probably a built in design failure so I'm forced to buy a new one. Corporate bastards!
  • 3 Answers
Dear Jim,
My own Tao unit is dying as well. Servicing does not appear to be available. The only solution I have found is to buy the Delphi MyFi unit which appears to use an identical interface (see page 10: http://file.xm411.com/manuals/MyFiUserGuide411.pdf ). What a bummer!
Digitally,
(/\/\<erwin
Posted on Nov 21, 2008
My Pulse Scout 49cc takes about 10 kicks to start in morning ok on electric start
Hi, Michael and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
10. Enricher valve inoperative.
11. Engine lubricant to heavy (winter operation).
12. Ignition is not functioning properly (possible sensor failure).
13. Faulty ignition coil.
14. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
Hard starting scooter 49ccScoot com Scooter Forums
Troubleshooting Your Scooter
http://www.scooterunderground.com/knowledge/manuals/documents/JetEuro50_Service_manual.pdf
Tao Tao 50cc Scooter Won Start SOLVED REPLACE CARBURATOR
Nov 18, 2016 | Motorcycles
Alpine cda 117
I dont think you lost the function of XM I think you just lost the Icon from the display, Go to where you setup the display (where you select what appears on the screen) there has to be an XM choice.
Oct 26, 2017 | Alpine CDA-117 In-Dash CD/MP3/WMA/AAC...
It does not turn off at the wsitch
When you turn the wall switch can you turn it off to stop it .this will help me diagnose it .
Dec 23, 2012 | Badger 1 All Insinkerator 76039h 1/3 Hp...
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
Scooter starts but stalls after a few seconds. It has been stored for a few months.
Hi, Anonymous if your bike has been idle for months or years and does not want to start you will have to deal with a few remedies:
1. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
2. Remove your air cleaner and clean and re-oil per Mfg. specifications.
3. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
4. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
5. Replace spark plug with a new one and check for spark.
For more information about your question please visit the website below. Good luck and have a nice day.2012 Tao Tao 50cc scooter BMW C1 scooter stall at idle after normal start FOUND IT
My chinese scooter wont idle or start Check the fuel petcock
http://www.benelli-scooters.de/pdf/BA_Benelli_Velvet125.pdf
Benelli Velvet 150 2014 service manual DOWNLOAD FREE FULLMANUALS COM
May 20, 2010 | 2008 Benelli Velvet 150
I was playing this one song I liked really loud
More then likely you damaged the amp and it will
need to be serviced!
Mar 16, 2010 | Onkyo TX-8511 Receiver
My Tao won't turn on and when I put it in the craddle all it does is blink
Probably bad battery. XM actually recalled original batteries and supplied new replacements.
Oct 25, 2009 | Tao XM2go Satellite Radio Receiver
No longer charge
Probably battery. XM recalled original battery and supplied new replacement. Or buy a new battery.
Jul 06, 2009 | Tao XM2go Satellite Radio Receiver
Roady 2 signal goes in and out....
We've been having the same problem with our Roady XT unit at the office. Sometimes I think it's possessed because it goes in and out, changes to the mute mode, and sometimes turns itself off. Just got another Roady XT unit today. It played fine, then went into the mute mode. Called XM and they told me to reset unit to factory default. It's fine at the moment.
Jun 01, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
PS3 with no Power?
it might be the wall plug try a different one
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
Tao XM2go Satellite Radio Receiver Logo
361 people viewed this question
Top Tao Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tao Audio Player and Recorder Expert? Answer questions, earn points and help others
