Question about Rio Carbon MP3 Player
Rio Carbon 5 GB: Battery loses power fast when player is turned off
Greetings earthlings,
I am Lur of Omicron Persei 8. No, I'm not. Just joking. ;-)
I have a Rio Carbon 5 GB player for some years now and like it a lot because of different reasons. Although I used it a lot it still works very good. Therefore I was looking for another player of this kind to use it beside of my existing one. Because I did not find a shop again in which they were offered new I bought one on eBay. It is also a Rio Carbon 5 GB. To my regret this one has a problem. The battery loses its power very fast when the player is turned off. In detail the battery is empty in about one hour in turned off mode after it was charged fully over the battery charger before and the cable was disconnected. Instead of that the player was already able to play over ten hours when the playing started just after the battery was fully charged. And after this playing time it still had power left. Thus it does not look like the battery itself is the problem. So far I have not found information to similar problems on the internet. Does any of you know similar cases and/or what could be the cause and solution? When I got it the installed firmware was Developers Cut 3.04. To test if it solves the problem I changed it to version 1.43 but the problem is still there.
Thanks in advance. 8-)
Bye,
John
  • 1 more comment
  • JohnDBlue Aug 15, 2008
    Hello Mowcius,
    Thank you very much for your answer to my query. It's a pity that the symptoms of my Carbon aren't familiar to you. I was hoping that they could be solved over a software setting. I will try your charge and flatten suggestion although I do not think that it's likely to solve the problem. But it seems to be worth a try. Unfortunately it seems increasingly likely to me that the problem is caused by a malfunctioning hardware. On the Internet I found information to other electrical devices with similar problems. In these cases malfunctioning hardware had to be repaired. But I think that the cost for a repair of my Carbon could be too high to be reasonable. Maybe I will try your suggestion to take off the back to look for a hardware fault if the above approach does not solve the problem. Or I leave it as it is. In this case I could start to schedule the use of this Carbon and try to charge it just in time with the energy which seems to be needed for the scheduled use so that I do not waste energy if possible. This seems to be a relatively inconvenient approach. Or I stop to use it and try to sell it as a malfunctioning device or keep it as a source for spare parts for my other Carbon. Or I try to give it back to the eBay seller. Because so far I do not know if your suggestions will solve the problem I am planning to rate your answer after I found out. Maybe I will write another comment when I have further information.
    Thanks again for your kind support. 8-)
    Bye,
    John
  • JohnDBlue Aug 30, 2008
    Hello Mowcius,
    So here some information to the actual status:
    I have tried your charge and flatten suggestion for some time in which I charged and flattened the battery for about five times. In one case I found out that my Carbon was able to play 15 hours in one go with a full battery charge before it went out of power which is a good length in my opinion. But unfortunately this procedure has not changed the problem. This Carbon still loses a full battery charge in about an hour when it is turned off. Therefore this strategy does not seem to solve this problem so that I won't try it any longer.
    I have not tried your suggestion to take off the back to look for a short circuit or obvious hardware fault because after I found the following picture of an open Carbon it does not seem to be likely to me that I could find such problems. See:
    So far I have not decided how to continue. Maybe I should try if this carbon blends. ;-) (See: www.willitblend.com) Just joking, of course I won't.
    Because your answer was helpful to me I will try to rate it with the rate Helpful.
    Bye,
    John
  • JohnDBlue Oct 13, 2008
    Hi Mowcius,
    Thanks for your answer from 30.08.08. Because off different reasons I have not answered it until now. Sorry!
    After 30.08.08 I also found your following two Carbon contributions on fixya.com:
    Replace broken scroll wheel on Rio carbon
    http://www.fixya.com/support/r639305-rep...
    REPLACE BROKEN HARD DRIVE IN RIO CARBON WITH CF CARD
    http://www.fixya.com/support/r590688-rep...
    In my opinion they are really good and helpful. You really seem to know how to handle some relatively difficult problems that can occur with a Carbon. And you even have replaced the harddrive with a compact flash card successfully. Hats off!
    Thanks for your further specifications from 30.08.08 about your earlier suggestion for a possible solution to the problem of my Carbon. So far I have not tried this approach because of different reasons. Based on the information I found about how to open and close a Rio Carbon the risk seems to be relatively high that problems occur in these activities. These procedures seem to be relatively delicate and difficult. Further more based on the described behaviour of my Carbon it does not seem to be likely enough to me that dirt or foreign objects are causing the problem of my carbon. Instead I tried to find a company here in Germany which offers repairs of Carbons for a fair price. Unfortunately I did not find one. At this point it seemed to be meaningful to me to look for an alternative to this Carbon. Based on this development it did not seem to be meaningful to search for another Carbon. Therefore I searched for other MP3 players on the internet which could be suitable to my wishes and are still offered in shops. Luckily I found one. It is the Sony NWZ-A818 B and to my pleasure I was able to buy me one. Here is a picture of this player:
    Great sound, 8 GB flash, easy and clear user interface, drag & drop access and a lot of other elements which are nice to have to me. So at last at present I have reached a constellation which fulfills my present wishes. I have two functioning MP3 players that I like. My old 5 GB Carbon which still runs great and my new NWZ-A818 B. So far I have not decided how to continue with my defective Carbon. At present I have no ambitions to spend further efforts on it. Maybe in the future.
    Live long and prosper!
    Bye,
    John
    Guru:
  • 155 Answers
The battery is not normally something that wears out on a Rio Carbon but if it used and charged wrong then it can either be conditioned to a shorter time or wrecked. Because it goes flat when turned off but keeps charge when on makes me slightly confused but anyway... I would advise charging it up fully and then flatten it fully - just leave it playing while you're out or something. Do this a few times and this may solve your problem. This will put maximum charge into your battery and it might solve your problem. If not then try taking the back off and look for a short circuit or obvious hardware fault.
Hope this helps,
Mowcius
Posted on Aug 03, 2008
  • mowcius Aug 30, 2008
    What you cannot see in that photo are the battery contacts under the battery. These were mainly what i was recommending that you check. There may some obvious dirt or some such foreign object in your rio which is causing it to malfunction but there may also not be. If you take off the back and there is no obvious fault then i am afraid that 'will it blend' might be the best option because due to rio being 'dead' there is no longer anywhere that will repair rio products (unless there is some guy doing it on small scale for friends)
    Sorry there does not seem to be a real solution to the problem,
    Mowcius
BATTERY FOR A RIO CARBON (5GB ) mp3 pLAYER
1. look on ebay for battery if anybody would sell one.
2. go to walmart look in the flash drive isle for a sandisk ultra 2 cf card 8gb about 40$ .
3. open the rio and take out the old hard drive and then find a pc to format the cf card with a cf card reader make sure to format with windows 7 in my computer and choose quick format select default allocation size and then hit start.
4. when succesfully formatted put cf drive in rio carbon.
5. then put back plate back on carbon.
6. then look here for rio carbon developers firmware
http://en.wikipedia.org/wiki/Rio_Carbon
7. go to bottom of wikipedia page and click 3.04 Download link 1 and download the exe program and then run as administrater load up the firmware and then walla you have a working mp3 player again.
Sep 03, 2012 | Rio Carbon MP3 Player
When I transfer music from Rio Music manager to my Rio Carbon the music manager indicates transfer successful but the MP3 player states no tracks present?
Try to transfer the tracks from the explorer.
1 Connect the Rio Carbon to a computer using the supplied USB cable.
2 Double-click My Computer on the Windows Desktop or in the Start Menu.
3 Locate MP3 or WMA audio files on the computer.
4 Highlight files and/or folders to transfer to the Rio Carbon.
5 Click Edit.
6 Click Copy.
7 Double-click My Computer on the Windows Desktop or in the Start Menu to open another window.
8 In the new window, locate the Rio Carbon (X:) icon that is associated with the Rio Carbon. (X equals the drive
letter assigned to the Rio Carbon.)
9 Double-click Rio Carbon (X:).
10Click Edit.
11Click Paste.
May 24, 2010 | Rio Carbon MP3 Player
Rio carbon 5 gig mp3
The Rio Carbon will not play songs from iTunes unless they are in mp3 format. If you cannot download the songs in this format then I would recommend a program such as mediacoder to convert the tracks. I don't know why iTunes was recommended for the Rio but I would just use drag and drop into the folder called Music on your Rio.
Hope this helps,
Mowcius
Oct 17, 2008 | Rio Carbon MP3 Player
Rio carbon can figure out how to get the download into the rio
The 3.04 developers cut firmware gives you a volume control via the bottom of your menu. You can get it from:
http://www.fixya.com/support/r624838-3_04_directors_cut_firmware_rio_carbon
follow the link.
Hope this helps,
Mowcius
Btw, i will also be posting a tip on how to fix a broken scroll wheel on a rio carbon soon so have a look in a couple of days (maybe even tonight) and i should have done that.
May 26, 2008 | Rio Carbon MP3 Player
Tranfer from player to computer?
Go to Main Menu -> Settings -> Advanced -> Transfer Mode and select MSC. Worked for me.
Nov 18, 2007 | Rio CE2100 MP3 Player
Rio Carbon Pearl mp3 won't charge
tr y to get a new battery. but it is tricky to get the old one out so take it to a store that deal with it.
Nov 12, 2007 | Mach Speed Trio Portable MP3 Player
Volume Control on a Rio CE 2100 (2.5 GB)
This is a hardware issue - there is no repair svc for this one. sorry.
Oct 28, 2007 | Rio Carbon MP3 Player
My Rio says upgrader when I turn it on
UPGRADER is a mode that purges the firmware from the Rio player prior to flashing the unit. Firmware is basically the operating system for the player, so if it is corrupted any number of things can occur. You can enter UPGRADER mode to update the firmware on your player by holding down the MENU button when you power the Rio ON. Flashing the player in this mode erases all content. Try the following to get the unit out of UPGRADER mode, if powering OFF the unit will not correct it. ALL PLAYERS - If you accidentally entered UPGRADER mode, turn the unit OFF and then back ON again. - Download the latest version of the firmware for your player and upgrade the unit. Visit http://www.digitalnetworksna.com/support/rio - It may be necessary to run the firmware update more than once. - This process may erase content from your player. - If the player is detected by the computer, it is recommended that you format the player, which WILL erase content from the player. - Macintosh user's try flashing the player on a PC. FLASH MEMORY PLAYERS - Remove the battery and replace it, this will reset the unit. The Rio Forge, Rio se510, Rio Cali [Black Rio Stick], and Rio Chiba [Black Rio Stick] can lock up causing the player to be unresponsive. If this occurs there are two things that need to be performed to resolve the issue. First you want to remove power from the player this includes the battery and a USB connection for 20 minutes to reset the player. There is a capacitor on the player that stores a charge that holds the player in the locked state. By waiting the duration the capacitor will discharge and the player should function as normal. Second you will want to upgrade the firmware to the latest version and format the player to prevent future occurrences. HARD DISK DRIVE PLAYERS - If you have a Carbon, Nitrus, Eigen, or Karma, use a paper clip to reset the unit. Your Rio will power off automatically when it has been reset. It may be necessary to connect the player to AC power and then reset the player if it will not turn on. If you are still unable to have the player exit UPGRADER Mode, then try it on another computer. UPGRADE FIRMWARE - Connect to the internet - Go to http://www.digitalnetworksna.com/support/rio/ - Click on the appropriate player - Click on the FIRMWARE tab [showing by default] - Click on the latest firmware file [example: RioForge_firmware_133.exe] - Click SAVE when prompted - From the SA
Feb 14, 2007 | Rio Forge Sport Digital Media Player
Rio Carbon powers off
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Sep 25, 2006 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
590 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
