Question about Bernina Artista 180
Bernina artista 640 embrodry - Bernina Artista 180
For a 640: Make sure the machine is off then Press the reverse button and the needle up/down button at the same time and keep pressing while turning on the machine until the service screen come up. Select the "i" icon and then the icon that has a picture with the clock and a question mark. That will show you the hours and stitch count used. To exit the service program just turn off the machine.
.g_thread_answer { overflow:visible !important; }
Posted on Aug 24, 2009
LED display is black or very dim. Bernina artista 640 machine. Have researched on line, with no help.
There is usually a way of dimming the LED screen, but if that doesn't work, it's possible a computer component is dying.
Oct 16, 2017 | Bernina Sewing Machines
Replacing the s board in a Bernina 640
What is your question? Can it be done? Yes, but you'll probably want a Bernina tech to do it if the part can be found.
Dec 10, 2016 | Bernina Artista 640E Sewing, Quilting and...
I want a diagram for oiling my Bernina 640 sewing machine
Hears the first video that came up on a youtube search: https://youtu.be/hJCRfpO_MVo
Nov 02, 2016 | Bernina Sewing Machines
I have a bernina artista 640 and the material is not moving i tried on plain stich with the 1 c also
the feed dogs need to be checked on the machine, they are the ones that move the fabric thru the machine.
Mar 01, 2015 | Bernina Sewing Machines
How to Turn Off the Bobbin Sensor in the Bernina Artista 640
make sure you're using the appropriate bernina bobbin, others can confuse the sensor. This video(by Bernina Boys) shows how to clean lint to prevent this problem which is what often causes this error. Or go into settings by pressing the diamond with right hand arrow inside of it. The eye with the speaker next to it should get you where you need to go to turn it off.
The manual on Bernina's website is here:
https://www.bernina.com/en-US/SupportData/BERNINA-Nah-und-Stickmaschinen/artista/Manuals/031508-50-04_0601_a640_EN
page 98 has the information you want.
Jan 22, 2015 | Bernina Sewing Machines
I have a Bernina 180 with embroidery module. If I upgrade to a Bernina 640, would it work with my 180 module?
Unfortunately no, I think that the 185 and beyond use the same emb module. The 180 if I remember correctly, has the memory and card reader in the module itself and may have a different plug. I do know for sure that the 180 hoops will definitely not fit on the newer modules. Sorry to disapoint, Allen
Feb 03, 2011 | Bernina Artista 180
How do i remove the hook from the bernina artista 640
If you remove the hook on a 640, the timing of the machine will need reset, and that involves pinning the machine for precise timing!
Aug 09, 2010 | Bernina Artista 180
Can you tell me what the bobbin image on the artista 640 means? It will only sew for a few stitches and then stop
Hi, most likely your bobbin sensor is being blocked by something. Common causes are a dirty sensor. Q-tip on the eye of the sensor inside the bobbin door. Or there is fuzz blocking it. Next take out the bobbincase and the bobbin. Look in the bobbincase and you will see a round spring. This spring acts like a brake for the bobbin. Sometimes these springs will get moved and out of position blocking the little space that the bobbin sensor reads through. Reposition the spring so you can see through it and the bobbincase.
That should do it.
Good luck.
Rick Engel
Bernina tech
Mar 02, 2010 | Bernina Artista 180
Unbalanced lower tension when using BSR free motion quilting
try using a straight stitch plate, this will help resolve some of the eye lash effect.
Apr 05, 2009 | Bernina Artista 180
Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
Mar 26, 2009 | Bernina Artista 180
Sewing Machines Logo
572 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
