Question about Sony Ericsson Walkman W810i Cellular Phone
Play Caller Name
What exactly is "Play Caller Name" in W890i ? It says in Inf that - 'Select On to hear the name of the caller when the phone rings, if you have saved a voice command for that caller'. BUT it doesn't work. Please suggest & help !
  • 87 Answers
Insert the headset and do it
Posted on Aug 15, 2008
  • bpc3890 Feb 03, 2011
    caller name kase on karneka
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
How do i set up my caller id on the samsung B2100?
To set Caller ID you need to save the persons name and number within the PHONE MEMORY, once saved then go to 'My Photos' and select appropriate photo and select 'Options' then '5.Set As/Caller ID' then search for relative number on the PHONE MEMORY once found confirm it by pressing left soft key which will save picture to number.
Jun 12, 2011 | Samsung Lands Phones
How do you turn off talking caller ID on panasonic kx-tg4032?
This feature lets you know who is calling
without looking at the display.
To use this feature, you must:
- subscribe to a Caller ID service of
your service provider/telephone
company.
- turn this feature on (page 24).
When caller information is received, the
handsets and base unit announce the
caller's name or phone number received
from your service provider/telephone
company following every ring.
The unit announces in English only.
L Name pronunciation may vary. This
feature may not pronounce all names
correctly.
L Caller ID service has a limit of how
many characters can be displayed. If
the caller's name is too long, the
handset may not be able to display or
announce the entire name.
L The announcement is heard at the
same level as the ringer volume (page
16, 23).
L If you turn on the answering system
and set the number of rings "2
rings" (page 36), the unit does not
announce the caller information. If
"Toll saver" is selected and there
is a new message, the unit does not
Mar 24, 2011 | Panasonic KX TG4032 19 GHz Twin Cordless...
Every time I get a text message it alerts me by saying "Message from _____" and then the name of the person. I want to silent this feature but I cannot find the feature to do that.
What kind of vacuum is this anyway???
I will try to help you with your problem even though you have not identified your make and model phone and you are in the wrong category. I will try to help you by telling you what I would do with my phone to change this setting. The procedure for changing your phone is probably different ... but perhaps you will get some insight from my remarks.
This is for calls and messages - My phone is a **** style LG. On the left side there are two buttons. I press the bottom one to get a menu list. Next I press the Right Soft Key called 'settings'. Next I select item number 6 called "call alert" I press OK. My three options are ( ) ring only or ( ) Caller ID and Ring ( ) Name Repeat.
I use (>) caller ID + ring and I hear the number or the name of the caller if in my phone book then the ring I have selected for that caller or texter.
Specific for messages ... I select Settings & Tools then I select Sound Settings then I select Alert Sounds then I select Test Messages and then I make my setting.
I hope this assists you with your settings even though I feel you probably dont have the same phone as I.
Thanks for your interest in FixYa.com
Sep 29, 2010 | Vacuums
My wife has a Nokia 6650 and when people call the number is displayed but he name won't she is getting very upset and the book sucks.
Caller ID works by displaying the caller infomation that is sent. When you receive the caller ID, it first tries to pair it up with a name in the address book, and if nothing is found, it just displays the number.
If you want the contact's name to show, then you must save it exactly as the caller ID displays it. Most often, only 7 digits are put in, when it needs to be the full 10 digits.
Jun 29, 2009 | Nokia 6650 Cellular Phone
How the "play caller name " system is work. plz tell me all steps
Goto menu>setting>General>Voice control>play caller name>select on
then back to voice control>voice dialing>activate>edit names>then record sound for desired caller name...
Jan 15, 2009 | Sony Ericsson K530i Cellular Phone
Caller picture and ring tone
Caller Picture:
i) go in the option Phone Book---> Add a New Entry----> To Phone(Not in To Sim)----> you will get all        option such as name, office no, personal no, caller picture, caller video..
 you will get these option only when you store the number or new entry in the phone memory rather than sim memory
                                                            OR
ii) type the number you want store and click the option save and now save in the phone memory rather than the sim memory, you will all option such as name, office no, personal no, caller picture, caller video..
ring tone:
go to memory card or any other place where you ring tone files or song files are present try to highlight it(dont click it) and at the bottom you will 'option' click on it you will get a list of option in that you will have 'set at ring tone' clik on it and you'll be able to set your own ring tone....
Dec 22, 2008 | Dual Electronics CECT P168 Cellular Phone
W890i wont ring, or play text alerts.
I cant hear it ringing while incoming call from any caller it just vibrate only.Any Idea how to solve this problem.my phone has the latest update from SEUS.
Nov 16, 2008 | Sony Ericsson W890i Cellular Phone
Caller id
Save your contacts to the phone. Personalized caller ID only works from the phone, not the sim. Go to contacts then press the contact name once to select it.  Press the menu button (bottom left) on phone and scroll to 'copy to phone'.  You should see the caller name when they ring then.
 (I bought a sim back-up device so that I can keep the sim clear. If caller information is on both the phone and sim it gets listed twice in your contacts).
Dec 24, 2007 | LG Prada KE850 Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
494 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
