Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Problem with phillips 60 projection tv
I own a phillips 60inch 60pp9202 rear projection tv all of sudden while watching its shuts off . i try to power on all i get a clinking sound . can u please help experts. thanks
  • 138 Answers
Possible cause could be a defective HVG (5904). Replace part with part number listed in this service manual.
Possible cause could be a defective Convergence
Amps (7044 and 7045) on Small Signal Module.
Replace part with part number listed in service manual.
Posted on Aug 19, 2008
I have a Phillips rear projection tv model number 60PP9202/17F.....it 60
What is the problem of your
Phillips rear projection tv model number 60PP9202/17F?
Jan 10, 2012 | Philips 60PP9202 60" Rear Projection...
My Philips 60inch widescreen rear Projection the picture color is blue and red how can i fix it
Tv problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Philips 60PP9202 60" Rear Projection...
Projection TV Phillps 60PP9202/17F, bought 2004. Was watching and suddenly the picture went out. All connections are good and components work. Can you help?
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV is in protect mode.
In protect mode higher voltages from PSU gets shut down and TV remains in standby.(see also Why my TV does not start up and remains in...)
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Then connect powr
If that does not work, and you keep having the TV in protect mode, it means that there is a fault.
In that case call the support number listed on Philips user manual to arrange repair.
If you are a technician I can try locating parts, service manual and giving more directions. Common faults that affect a Philips rear projections are convergence, PSU board, lamp and ballast assembly.
Regards.
May 28, 2010 | Philips 60PP9202 60" Rear Projection...
Our phillips 60" TV
Ur convergence is dead.Know how to solders?Must changed the 2 convergence ICS,and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergencce kit.The shop will cost $300 for parts and labors.
Feb 01, 2010 | Philips 60PP9202 60" Rear Projection...
When watching tv the images are green and red on a Phillips 60pp9202 rear projection
you have a convergence problem.
try to change the convegence output ic. stk392-120 with burnt resistors you're gonna see.
Oct 18, 2009 | Philips 60PP9202 60" Rear Projection...
I have a Phillips rear projection 60 color lamps off focus
You can't adjust this. Your convergence amplifiers are bad and must be replaced. $250-$350 by repair shop.
Jul 08, 2009 | Televison & Video
Turned off by itself and never came back what part will I replace
If the TV is completly non-responsive (ie not even a flicker of light on the power button) then one of the first things to check on this is the fuses - easiest being the right corner next to where the power cord plugs in (have to take off the back panel)
May 30, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
177 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
