Question about TTX Computers & Internet
Model ttx 9194 flat screen monitor
The monitor, coms on then goes black after a few seconds
Check all capacitors in the inverter section!!
Posted on Jul 29, 2008
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
My monitor is a dell 2000 flat screen 20.1" turns
It is not so difficult to repare if you have scills to open the monitor and scills in un-soldering/soldering electronic components, than yes it is worth it, but if you go to a shop they have a tendency to sell you another monitor since the price they charge to repare the powersupply is about the same as a new monitor
Feb 18, 2011 | Dell UltraSharp 2000FP 20.1" Flat Panel...
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
I have a Dell SE198WFP Flat Panel Monitor, screen goes black?
The LCd panel may be damaged and will cause this problem.
Another thing is overheating of the GPU.
The LCD signal receiver can be goign on you.
The is also the possibility of a faulty inverter.
Only thing to do is service or replace. Test the unit on another computer, if you don't get the issue there then you know its a problem with the PC.
Jun 03, 2010 | Dell SE198WFP LCD Monitor
The monitor goes black while on
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 12, 2010 | Hannspree HannsG HG281DP 28" LCD Monitor
I have a AOpen Flat panel monitor, model # F70VS. It comes on for a few seconds but the screen goes black. Can this be fixed or do I need to buy a new one?
try the monitor with another pc or laptop , if the same problem happens then yes seems to be a fualt with monitor
Nov 29, 2009 | Computers & Internet
My screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
LOOKING FOR DRIVERS FOR TTX 9154 USB TOUCH SCREEN MONITOR
I poked around the www.ttx.ca website for you, and found the following blurb:
"A. All models manufactured after 1999 are “plug and play” compliant, therefore “plug and play” drivers supplied with your specific system will work the same as the “TTX.inf” driver found on our website.
If so, here is the link to their "TTX.inf" driver.
http://www.ttx.ca/support/Monitor_Drivers_and_Manuals.asp
Now, a closer look on that page said "CRT Monitor", and that may not be what you have. I did stumble across another of their pages talking about Touchscreen Manuals and drivers. Find that here:
http://www.ttx.ca/support/Touchscreen_Drivers_and_Manuals.asp
This page says to match the last two numbers of the product ID on the back of the unit to their chart of drivers and manuals.
Hope that helps!
May 22, 2009 | Computers & Internet
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Computers & Internet Logo
204 people viewed this question
Top TTX Computers & Internet Experts
David Payne
David Payne
Are you a TTX Computer and Internet Expert? Answer questions, earn points and help others
