Question about E-Machines eMachines Desktop PC
How do I locate the TCP/IP address? Thanks
I will have to try your suggestion when I get home. How do I locate the TCP/IP address. Thanks
    Problem Solver:
  • 44 Answers
Dear whitmeyer,
You can go to a command line (Start, Run) and type ipconfig to get you TCP/IP address.
Posted on Aug 01, 2008
Why does my hp envy 5535 stops in middle of print job
Please try following the steps below and let me know if that may help:
  1. Open the HP Envy 5535 software, then click the Printer Home Page (EWS) link.
  2. Click the Network tab.
  3. Click Networking , and then click Network Address (IP) .
  4. Click Manual IP , and then click Suggest a Manual IP Address . A manual IP address, Subnet Mask, and Default Gateway displays.
  5. Be sure to take a note of the IP address and Confirm the changes, then close the EWS page.
  6. From the HP Envy 5535 sotfware click the Utilities tab, then click on Update IP Address.
  7. Type the manually configured IP address, click on Save and confirm.
  8. Open the control panel and go to Devices and Printers.
  9. Right click the HP Envy 5535 icon and select Printer Properties.
  10. Open the Ports tab.
  11. Click teh Add Port button, select Standard TCP/IP and click on New Port.
  12. Follow the steps by typing the manually configured IP address and confirm the changes.
Read More... HP Printer Support
Jul 23, 2014 | HP ENVY 5535 E-ALL-IN-ONE PRINTER
Laserjet 4+ split
As one person suggested above, it is possible to share the printer between two machines. All you need to do is set it up as a TCP/IP printer and assign it an address (either through the DHCP server or by giving it a static IP address), then go into the two machines and add the printer as a network printer. When asked about the type of port to use, select Local TCP/IP port... and enter the IP address of the printer.
I recommend setting a reserved DHCP address through your router to insure that the printer keeps a constant address and to insure that the router does not accidentally try assigning the same address to something else and therefore cause an IP address conflict.
Apr 02, 2014 | HP LaserJet 4 plus Printer
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
I need gateway address, subnet mask and TCP/IP Address for canon irc2620n
IP Address:
Subnet Mask:
If fail suggest to set iRC2620N to DHCP so that your DHCP server or router to assign a TCP/IP address.
Dec 17, 2012 | ASUS K53e A1 Notebook
How can I print a configuration page from the E260dn Lexmark?
Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, then print a network setup page and locate the IP address
in the TCP/IP section.
Click Reports.
The following reports may be viewed from the Embedded Web Server:
Device Statistics
Device Settings
Device Information
Profiles List
Printer Server Setup Page
Jul 25, 2012 | Lexmark E260dn Laser Printer
How do i set the ip address for e250dn
Follow these steps: 1. Press the "Operator Panel" button to print a Network Setup page.
2. Locate the entry labeled "UAA" or "Physcal Address."
3. Write down the 12-digit address. An example is "00:1A:2B:3C:4D:5E."
Set the IP Address 1. Insert your Lexmark drivers CD and select "View Documentation."
2. Select "Software and Utilites" and click "IP Setup Utility" to start the program.
3. Enter the physical address for the printer in the "Discover Print Servers" field and click "Discover."
4. Select the printer from the "Configure Print Servers" list and click "TCP/IP Settings."
5. Click "Suggest Address" if you'd like the utility to locate an available IP for you, or enter the IP of your choice in the "IP Address" field and click "OK.
May 22, 2011 | Lexmark E250dn Laser Printer
I want to see ip address of vse mainframe how to check any one suggest me how to find out ip address please
Open a connection to the VSE mainframe, and logon.
Click Start
Click Run
Type CMD
Press Enter
Type NETSTAT -a -n
Press Enter
Look for a line of output like:
i.e,. look for 'TCP' and ':23' and 'ESTABLISHED'.
The value of "" is the IP-address of the mainframe.
Apr 22, 2011 | Computers & Internet
Belkin 54 g wireless router....cant find on the net. need to port forward to host games HELP!
Make sure your private IP address is statically set.  Your public IP address is obtained from your ISP and is what other users will be connecting to.  You can not manipulate your public IP address so if your ISP is running DHCP, it is very possible that your public address is changing.  Also if you are frequently disconnecting your modem, it is possible your ISP is leasing you a new public IP address each time.  So try to keep things as static as possible.  As far as the battle net stuff.
Diablo, Warcraft II Edition, and StarCraft:
Allow port 6112-6119 TCP and UDP out and in
Diablo II:
Allow port 6112 TCP out and allow established sessions in
Allow port 4000 TCP out (realm games)
Allow port 4000 TCP out and in (hosting open games only)
Warcraft III:
Allow port 6112 TCP in (hosting custom games)
Allow port 6113-6119 TCP out and in (hosting custom games if you've changed the default port in the Options/Gameplay screen)
If you are still having problems after you open up the required ports, try opening 116(TCP) and 118(TCP). I don't really know if these ports are required or not.
I have had people tell me that opening up those two ports have helped them connect to
Hope that helps.  For manipulating ports in your router I suggest consulting your user manual, or online FAQ.  Save your router config before applying any changes, and always remember, opening up ports subjects you to different types of security threats so be aware that is a risk you are taking.
Mar 12, 2009 | Belkin Computers & Internet
Xp home & wireless printer won't install
Add the printer in a TCP/IP port and assign it that IP address. /Add Printer/local connection then set it to TCP/IP port and the printers ip address.
Jan 15, 2009 | Microsoft Windows XP Home Edition
You are going to go to the tcp/ip settings and enter a permanent ip address.
If you access the internet you could always use the ip address you are getting from dhcp, just go to start-run and type cmd then at the command prompt type ipconfig and copy the ip, subnet, gw and dns to the tcp/ip settings.
Thank you for choosing agadycom.
Nov 13, 2008 | Microsoft Windows Server Standard 2003 for...
E-Machines eMachines Desktop PC Logo
94 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
