Question about Trendware 54Mbps 802.11g Wireless AP
The connection timed out waiting for the VPN server to respond. This can occur if your computer is behind a firewall that does not permit UDP or IPSec traffic. Contact your local network administrator
I am getting this probelm.
I have Linksys router of model BEFSR41
mansnes
  • 50 Answers
SOURCE: Can't connect to AT&T VPN
I'll need to know what router you're using, make and model, for more specific help, but sometimes there is an option for IPSec passthrough. For example, on my Linksys Wireless Router WRT54G, there is a set of buttons under Security/VPN that are entitled IPSec Passthrough, PPTP Passthrough, and L2TP Passthrough. Since I don't know what router you're using, I can't tell you wether or not your router supports such functions or not, but if it does, you need to enable them.
Posted on Mar 04, 2008
Hi, my dlink dir 600 is funished as an access point and i cant connect to the pptp vpn server from my university. What do i have to do?
the problem is most likely that your university blocks the pptp ports so you cannot connect to the VPN. are you able to access it if you plug your computer directly into the wired connection?
Sep 27, 2013 | D-Link Computers & Internet
How can i configure aip w505 for att elevate internet, in order to view my qc dvr
You need to enable the virtual server settings on the AIPW505
You also need to allocate a static address to the DVR within the range of the DHCP address range.
Virtual Server Settings - Selects between enabling or disabling port
forwarding the virtual server. (Default: Disable)
? IP Address - Specifies the IP address on the local network to allow external access.
? Port Range - Specifies the port range through which traffic is
forwarded.
? Protocol - Specifies a protocol to use for port forwarding, either TCP,UDP or TCP&UDP.
? Comment - Enter a useful comment to help identify the forwarded
port service on the network..
The manual can be obtained from here
ALFA NETWORK Inc
Oct 21, 2012 | ADVANCE Alfa AIP-W505 802.11n/b/g Wireless...
Hi, my Belkin N Wireless router works in some way fine with both Wired and Wireless connection, but there is a problem, it will only allow me to connect wired to my computer and not to my PlayStation 3......
You may need to change settings in your router to enable your online games to work. Some games need to use specific ports; these ports may be closed due to the router's firewall. Please refer to your game's documentation for the ports required.
Use the following answer to configure these ports in your router.
In order to configure this, you need to know:
- The IP address of the computer or device to have the port forwarded to.
- The port numbers to be used and whether these are TCP or UDP ports
(Note: We recommend you use a computer that has a wired connection to the router.)
Setup steps:
  1. Open a Web Browser on the computer. Type in http://192.168.2.1
  2. In the address bar of the Web Browser type Click Login in the upper right hand corner of the page. The router does not ship with a password, so just click submit.
  1. Click on Virtual Servers under Firewall in the menu on the left
  1. Enter the following information
    • Click Enabled
    • Type a general description of the application i.e.. Remote Desktop
    • Type the port(s) specified by the program manufacture for both of the Inbound port fields
    • Select TCP, UDP, or BOTH for the Type.
    • Private IP address: Enter the IP address of the computer you want grant access too.
    • Type the port(s) specified by the program manufacture for both of the Private port fields.
  1. Click the Apply Changes button
Jan 11, 2011 | Belkin N1 Wireless-N Wireless Router
How to create a port on my router
please follow the steps are given below,
1.Type 192.168.1.1 on your browser's address bar. You will see a login dialog box .
2.Type your username & password and login to device.
3.A web page will appear , you can go to security section & select virtual servers.
4.From virtual servers section you can create port you want either TCP or UDP.
best regards,
Krishan
May 09, 2009 | U.S. Robotics (USR5450) 802.11g/b Wireless...
How to change NAT type on sierra wireless 595u aircard?
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Feb 15, 2009 | Belkin N1 Vision Wireless-N Wireless...
Can not get my dsl internet to work
make sure that your firewall settings on your computer is not too high, check also your browser settings make sure that VPN and automatic settings are off , try using safemode with networking
Nov 21, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
VPN connection timed out
please tell me that who is your ISP at home?
Oct 25, 2008 | Trendware 54Mbps 802.11g Wireless AP
Siemens Gigaset SE587 WLAN dsl
Error #105 TCP connection to the server timed out.
IMPORTANT NOTE: If you have received this error, you are not using the latest RealPlayer. RealPlayer 8 Basic is a FREE, recommended update available for Windows 95/98/NT and recent Macintosh systems.
If your system meets the minimum system requirements, it is recommend that you update your player.
The attempt to connect to the TCP server took longer than allowed. This problem may be caused by a high network load (i.e. too many people on the internet) or the server maybe down.
If the load is too high, you may try later or you can increase how long your computer waits by changing the Network timeout values under the Connection tab in the RealPlayer Preferences. If the server is down, the only solutions are to try a different server or contact the server administrator for the site you are trying to access.
Mar 18, 2008 | SMC EZ Connect Wireless Networking Starter...
Mar 04, 2008 | Trendware 54Mbps 802.11g Wireless AP
How do I open ports in the Virtual Server?
You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows. 1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter. 2. Click on Login, Advanced Setup, NAT, Virtual Server. 3. Enter the port details and enable it as follows: Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx
Feb 19, 2006 | SMC Barricade 7004
Trendware 54Mbps 802.11g Wireless AP Logo
587 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Dan Castro
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
