Question about Goldstar Heating & Cooling
My Goldstar air conditioner (M60004R)has been making lots of bad sounding noises.From annoying 2 almost unbearable.Seems 2 keep getting water build-up.It's 2 yrs. old. And I can't find my manual that came with it.
  • 75 Answers
The water outlet is not properly getting exitted which causes to raise the water to the fans blades which causes noise building up.././
Posted on Jul 29, 2008
It is making buzzing noise inside
There are 2 possible cause of that noise 1 is coming from your fan motor and the 2 is the compressor stand is broken. Or water that never comes out on the pan of the air condition try to drain it first before proceeding the 1 and 2 tips.
Sep 11, 2011 | LG Goldstar GWHD5000 wall/window Air...
My goldstar window air conditioner keeps spitting water out of the vents and making a loud noise, what is it? Please.
Hello
Could be the drain hole is clogged up outside.
Its usually located on the bottom r h side.Needs to be unclogged.Use a thin piece of wire or compressed air or even a good blast of water to fix it.
Aug 30, 2010 | LG Goldstar GWHD5000 wall/window Air...
My window air conditioner is making very loud noises and it is not dripping water outside
No condensation means no freon flow in condensor which sounds like bad compressor which would account for the noise. Replacement would probably be most economical way to remedy.
Aug 12, 2010 | Goldstar KG6000R Window Air Conditioner
My air conditioner is making a noise and leaking!
mcdevito75 here, Have your A/C looked at by your local A/C repair shop. Sounds like the compressor is makeing the noise (expensive repair if so)
Jun 22, 2010 | Goldstar KG6000R Window Air Conditioner
Leaks water from back
this is not a water leak ! it is the humidity in the room which collects as water and drains out at the back.keep a bucket underneath or attach a drain pipe to the outlet .
May 31, 2010 | Goldstar WG8000 Air Conditioner
Window Air Conditioner Sound/Vibration
It sounds like the compressor may be "Short cycling" (turning on and off too quickly) if it is the compressor doing this there may be a problem with the termostat, the charge on the system, or the compressor itself. If it seems to be cooling correctly you may need to add a brecket to the unit outside or add some rubber or sound absorbing material between the unit and the window sill. hope this helps
Jul 31, 2009 | Goldstar KG6000R Window Air Conditioner
GoldStar model GWHD5000
Make sure that the unit is properly mounted in the opening (I take it it's in a window) and that it is level or at least not tipping inward as in the outside being higher than the inside. If unsure about how to mount it properly, consult your owners manual. Your installation should be reasonably close to the illustrations.
Jul 13, 2009 | LG Goldstar GWHD5000 wall/window Air...
My air conditioner is making noises
You must look into the machine and find where the noise is coming from. Only then can a person recommend what to do about the noise.
Jul 24, 2008 | Goldstar Heating & Cooling
Lost manual
No, you don't put water into air conditioners. They make their own water and it is an inconvenient by-product that needs to be disposed of in some way. The A/C will use the outside fan blade to fling the water on the hot coil, let it drain out, or both.
Jun 04, 2008 | Goldstar R1003 Air Conditioner
Heating & Cooling Logo
185 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
