Question about Frigidaire FGB24S5A Gas Single Oven
Oven My oven will not preheat properly. Do I need a new thermostat?
  • 75 Answers
There is a thermostat adjustment screw which you can adjust to get preheated properly
Posted on Jul 29, 2008
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
Display shows err 08 message
It looks like a Samsung Oven and the E08 is a preheating error
It could be a relay or a defective Thermostat. If U have food in the Oven during the preheating that can cause the error as well...
The error occurs if the oven doesn't reach its tempt with in 50 mins
Dec 22, 2012 | Ovens
Oven preheats but will not maintain heat
Hi you have a bad thermostat for the oven , I would guess that everything else is working ok on this unit correct ? if you send information i will look up the part for you this is easy to replace , as always turn the power off before service or unplug
Nov 25, 2011 | Maytag Ovens
I hit the bake button on my oven and after 10 secs it says preheat and thats all that happens nothing else no heat at all
Your oven will continue to indicate that it is preheat mode until the thermostat senses the proper set temperature. If you are getting no heat then you will need to address that issue. This could be many things but the most notorious would be the heating element. Could be the control panel as well. Some ovens have a knob for preheat, bake and clean with a separate knob to adjust the temperature. Make sure both are set properly.
Regards, Tony
Apr 07, 2011 | Kenmore Ovens
Oven does not get to temp when it says its preheated
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
Feb 10, 2010 | GE Ovens
Preheat takes too long
does the oven bake properly when it does reach temps?
if this is a newer oven, with a hidden bake element, they do take longer to preheat so may not have any problems, just give it about 15 minutes to preheat.
if it is older and doesnt bake right, then you may have a bad bake element.
the unit will heat but wont bake right.
unplug the oven and take the bake element to your local parts house, they can check it and sell you a new one if needed.
Jan 10, 2010 | Frigidaire Ovens
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
208 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
