Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Original problem ...
Vizio P50HDM - Big Bang! Got my picture back by replacing y and z boards but now it's blinking/flashing - brief blackout about once a second.
  • 1 more comment
  • Martin Zitter Aug 08, 2008
    I replaced the upper and lower boards you said would solve the "blinking" problem and it's still blinking.
  • sianna06 Dec 30, 2008
    Well, we plugged in an Xbox 360 for the first time into our 42" not sure if that had anything to do with as it was working fine soon after we had gotten done playing. We only played for a few short hours after unplugging. Again it was fine right after. And just now we tried to turn it on and it won't turn on all the way, it won't stop blinking. The Cable picture won't even come up it just stays blue and blinks. From reading the rest of the problems it sounds like something is broke.
  • wpooh1022 May 11, 2010
    i have had the same problem and plan to replace y and z along with the upper lower boards to make sure it is correct. i am alos going to install 2 fans that you suggested. What size CPU fans should be used and do you recommend any where to purchase them.. Thanks
I had this problem with my P50 vizio when i started to use a new digital cable box from cox. i had them send me a hdmi cable box and had the problem not as offten, (meaning the T.V. Flickering on and off). i unpluged the t.v. for about 5 mins. turned it on went to menu and down to master reset option under advance settings. and had not had a problem for a year. then today my t.v. powers up and picture trys to come on and then nothing just blank screen, but have power light.
Posted on Jan 18, 2009
    Scholar:
  • 52 Answers
Depending on where you got your boards from and if they were a matched pair, other than swapping out a board, there are a few other things that need to be done.
There are quite a few voltages that go to the z zus and y sus boards.. If you are getting a flashing picture, one of the volts is probably not setup correctly for your panal. There are VS, VC, SCAN, VE, Vsus, and etc... The back of your panal has a sticker that will tell all the voltages for the panal. Check the voltages and adjust to correct spec and some fine tuning is also needed, those volts are just a starting point.
Posted on Aug 13, 2008
    Problem Solver:
  • 8 Answers
There are two additional Y Sustainer supporting Boards called the Upper and Lower Y Boards in the P50HDM that can also be replaced at the time of the Z and Y Replacement. There part numbers are: 6871QDH088A and 6871QDH089A. Although some techies prefer to replace them at the same time as the main Z & Y Boards you won't know if they are the problem unless you still have problems after the Z &Y are replaced at the same time. Since these are much cheaper than the Z & Y (about $50 each) that should take care of the blinking.
It sounds like you don't have the dreaded problem of busted panels otherwise you wouldn't have a picture at all. these boards are actually pretty cheap unlike the Z and Y which are a bit more expensive. It’s also popular to add two additional CPU fans to the unit for additional cooling. Apparently the POD (Pop of Death) has something to do with the main Z and Y overheating. To add additional CPU Fans, which are also pretty cheap, you’ll need a 3 Pin Y-Splitter (M-F) for the extra plugs to connect to the additional fans but be sure to purchase a super quiet fans since the additional fans will be running along with the two 5 inch super quiet fans that came with the unit.
Posted on Aug 01, 2008
I have a Vizio p50hdm while watching heard a pop noise and tv went out cant turn back on.I replaced main board and power board and still doesn't come on any Ideas?
The power amplifier chip (which goes "pop" when it goes bad) may be located on the board where the IR sensor is. Sometimes (but not always) you can make the TV come on by holding the power button in _until_ the TV comes on. But that usually only works when the chip is "going" bad. If you heard the pop, it's probably shot. Also, check for a fuse on _any_ of the boards, and possibly a main fuse at the back of the TV.
Mar 09, 2016 | Vizio 50" p50hdm high definition...
Followed you instructions ...
What was the original problem with your unit?
Jul 29, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDM Plasma
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jun 23, 2014 | Vizio 50" p50hdm high definition...
Picture went out on Vizio P50HDM
Check you voltages before just swapping out boards. Although a YSUS is common for no picture, so is your upper and lower Y Buffer boards or the panel itself. Check youe -VSC voltage. Does it look like it is being loaded down? If so then your YSUS is not the problem. You can run the set with just the upper or lower Y Buffer boards untill the load is gone. That will let you know wich board to replace.
Jun 20, 2012 | Vizio Televison & Video
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio p50hdm red flashing pixels
Try to adjust the Vs voltage on the power supply by lower it a little bit or increase it a little bit. It will help to decrease the red pixel flashing.
Apr 24, 2009 | V, Inc. Vizio P50HD Plasma Television
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hi, I have a Vizio P50HDM
For your Zenith P42W34D TV. The problem cause the a bad Y drive board. Replace the board will fix it.
Hope this will help.
Jan 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
549 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
