FixYa.com
Tags:
Vivitar 285HV Flash
Vivitar 285HV Flash Test Button Question
By pawa - usenet poster
Hi all,
I recently purchased a used Vivitar 285HV Flash.  My Fuji Finepix S602
seems to have trouble triggering the flash reliably.
On the flash, there is a flash test button - sometimes I have to press it a
couple of times before the flash fires.  Is this normal?  Other flashes I
have used fire EVERY time the test button is pressed.
Anyone else have a similar experience?
Thanks.
Lucas Tam (REMOVEn @rogers.com)
Please delete "REMOVE" from the e-mail address when replying.
http://members.ebay.com/aboutm e/coolspot18/
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 11, 2005
Helpful (85)
kioner
kioner - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It should flash every time you hit the red reset button. Check the
integrity of the contacts of the battery cartridge, both cartridge and
inside the flash unit. The capacitor is not fully charged until the back
lights flash green and red, but it should still discharge when you hit
the reset. I learned on my Oly C-4000, however, that I can only get it
to discharge if I'm in the camera's manual mode if it's plugged into the
camera. Good luck.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Putty
Putty - usenet poster
Rating: 0%, 0 votes
"Mike Fields" <mr.gadg @attbi.com> wrote in
The flash works much better on AA batteries (I was using NiMHs before).
It seems I need to wait about 5 - 10 seconds after the red/green starts
blinking before I can get a reliable flash.
It could be a problem with the capcitator.
The flash I got seems to be in REALLY good condition... almost brand new,
so I find it odd.
Luckily there is a Vivitar repair centre in my city, maybe I'll drop it
off and see how much it costs to get it to fix it.
It's only a minor nussance - I just hope I don't miss any shots because
of it.
Solution #3
Not Rated (0)
kioner
Rating: 0%, 0 votes
Hmmm -- I have been using NiMh in mine recently and
it works fine (although the HV may be different).
Mike "mikey" Fields
http://home.attbi.com/~mike.fi elds/
outgoing email scanned by Norton Antivirus ... is that good ?
Solution #4
Not Rated (0)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
I have the 285 (not the HV) and the button triggers it every time
I do the "push to test".  Make sure the red/green light is showing
charged before you test.  For some reason, flashes seem to have
a problem with battery contacts and you may not be charging all
the time.  On the other hand, if the red/green is flashing and the
push-to-test does not work, there is a different problem.
Mike "mikey" Fields
Can you Help with these Flashes problems?
Flashes
lights out
I was in my tanning bed and it... Answer This...
Flashes
firmware for the pdr-3300...
do you still have the newest... Answer This...
Vivitar 285HV Flash
vivitar 285HV & Skyport...
I have two Skyport trans &... Answer This...
Flashes
Restriction Code NOKIA 6030
Hello, I bought a cellphone in... Answer This...
Flashes
Built-In Flash
I'm only 17 and am somehow... Answer This...
Repair Service
Find Flashe Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
