Question about Toshiba DKT-2010H Corded Phone
Toshiba phone DTK2020-SD
When a fax comes across our main line, I am trying to con/trn to the fax number.
I thought the process was con/trn, 9(for outsideline), 363-7426 con/trn.
is this process incorrect? If so what is the proper process.
Thank you,
Jeana
    Scholar:
  • 108 Answers
Try to conf two outside parties with your phone to make sure the phons system will allow tandem trunking. Follow your example by dialing the first party, press conf/transfer, dial the second party, press conf/transfer, then press conf/transfer a third time to add everyone together. I think you are just missing the last step of pressing conf/trans the third time to add the lines together. Good Luck.
Posted on Jul 31, 2008
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
I have a panasonic hybrid phone system and would like to connect a fax machine, when I connect the fax to the jack, I dont get a dialtone but it goes to the intecom line. The same happens if I connect a...
Hello, you can solve this one of two ways. Try pushing a 9 when you get intercom line, you should get an outside line. So when you want to send a fax, just remember to push a 9, get outside dial tone then dial your number. Or, the second option would be to program that extension jack to auto select a line when going off hook. That will take a manual and some additional guidance. Okay, so thats for making outgoing calls. When it comes to incoming calls, you need to find out what extension the fax is connected to. You can do this by dialing another extension that has a display from the fax machine and see what intercom number comes up on the phones display. So once you know the extension number you can do one of two things. You can leave the fax off since it will most likely ring when any call comes in your office, and only turn it on when receiving a fax. When you answer the fax call on one of your other phones, and hear the beep beep beep, merely push transfer and dial the fax machines extension. That will transfer the incoming fax call to that extension and the fax machine provided you have it turned on. The other option is to break out the system manual(not user guide), and program the fax machines extension to only ring on the line you want it to, say your last line and leave the fax machine on and give out that specific number for faxes. But you do run the risk of your call traffic being heavy, incoming calls rolling over to that line or someone calling that number directly and getting the fax. I think I covered everything I can with the limited information on your application, so I hope that solved your problem.
Sep 17, 2009 | Panasonic Advanced Hybrid w/Back-Lit LCD...
How can i transfer calls from my Toshiba DKT2010-SD to another phone
To transfer calls, while on call press Conf/Trn and dial extension number. To Call forward your call to another extension there are three codes depending on what type of forwarding #601 - #604. Your guides and manuals are here
http://guides.idacomusa.com/
Jul 13, 2009 | Toshiba DKT2010SD Phone
Toshiba DK2010 phone
A conference call can be set up two ways. If its two phones at your office dial or receive call on one phone, press Conf/trn and dial extension of second phone, have them pick up reciever and press Conf/trn again and all 3 are on. For two outside lines it must be configured on your system to allow but it is then establish a call dial conf/trn 9 + number wait for answer and press Conf/trn again. Your tutorials and guides are located here.
Jul 07, 2009 | Toshiba DKT-2020 Corded Phone
Problem adding additional lines to calls
To "jump on" you would need to turn on executive override. Its in Program 30,31,35 in system programming. To conference call simply press Conf/Trn call the extension to conference in with. Have them pick up handest and press Conf/Trn again and you are all connected. More info and your manual can be found here.
Jun 11, 2009 | Toshiba DKT2010SD Phone
Conference call
To make a Conference Call
1. While on a call, press Cnf/Trn_____.
2. Dial a [DN] (or access an outside line and
dial an external telephone number).
3. Press Cnf/Trn after the called party answers.
All parties are conferenced together.
If you added an outside line to the call, press
Cnf/Trn again before hanging up to allow
the outside parties to continue talking. (If
you do not, the call is disconnected).
Note Some types of outside lines
(“unsupervised”) do not automatically
disconnect when conferenced parties
hang up. In this case, press one of the
flashing buttons to monitor the
conference.
If the parties are still on the line, press Cnf/Trn
+ Spkr, then hang up. When no one is
on the line, press Spkr to disconnect the
lines.
Mar 19, 2009 | Toshiba DKT-2020 Corded Phone
Transfer
Do you mean send the call to another phone?
Make sure the line is not on hold (push the caller's line) then push Cnf/Trn, dial the extension you want the call to go to, then hang up.
The person you're sending to will receive that call on their speakerphone button and it will ring in a different tone.
Jan 13, 2009 | Toshiba DKT-2010H Corded Phone
Conference calling
press the cnf/trn button dial an extension or an outside line and hit the button again after that call connects.
Oct 28, 2008 | Toshiba DKT-2010 Corded Phone
Using the transfer feature
dial the first phone #
when they answer, presss "Cnf/Trn" button
select a Line not being used and press 9 + next phone #
when they answer, press the "Cnf/Trn" button again and everyone should be connected.
Oct 08, 2008 | Toshiba DKT2020SD Phone
DKT2020 Conference Call
1) Make your first call. 2) Press the cnf/trn button. 3) Press one of your open line buttons on the right. 4) Dial europe number. 5) Let it ring a couple of times then press the cnf/trn button again. Remember your carrier or your phone system might have international calls blocked.
Aug 15, 2007 | Toshiba DKT-2020 Corded Phone
Toshiba DKT-2010H Corded Phone Logo
237 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
