Question about Motorola Mobility RAZR V3
Keypad doesn't work
A friend tried to send me a ringtone thru bluetooth. now, only the power button works. Even the volume control on the side doesn't work. I can receive calls, and when my phone connects via bluetooth in my car, I can make calls using the keypad display of the car but I cannot get any key on the phone to work. I have taken the battery out several times and at one point every key tried to launch a browser but it's back to no key working except for the power key. I have never locked it and it has not been exposed to moisture. HELP!!!!
  • 1,586 Answers
I'm thinking this may be a failure of the phone that is not related to the ringtone, unless there's such a thing as a virus that can nuke a cellphone. I've had two RAZR phones die on me (neither in this method), but anything with a keypad such as that on the RAZR will eventually have trouble. Stop into your provider's store and see if it's something they've seen and know how to correct.
Posted on Jul 31, 2008
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
The key pad on my Motorola V3s RAZAR doesn't work the only button that works is the power button. All the other buttons don't work, how can i fix it myself.
If you're going to do it alone,follow this steps.
1. try to check if the volume up or down is working,if not, remove the battery cover and dismantle the lower panel at the back using a T6 precision screw,unscrew 2 screws and by using your thumbnail look for edge cover,insert and lift it up gentle (remember that a flex connector is attach on the right side If done,check the volume switch and remove the circular metal (keypad membrane) that is volume high and low apparently.clean it and align it when returning back before assembling it(might some shortage or hang buttons that's why keys are not working).,also try to check if the flex connector or socket is clean as well as the board socket connector cause keypad function has the line with it.assemble it and try if its working.
2. If the method above fails,need to replace the keypad flex cable.it maybe to risky for you to do cause the keypad connector is connected at the upper flip panel.i maybe reliable if you continue and there's a chance to break the lcd cause upper portion is to hard to dismantle.better bring it a mobile service center for keypad flex replacement.
hope this simple solution helps.
Jun 19, 2011 | Motorola Mobility RAZR V3
Want to know if cs6319-4 VTech cordless phone has bluetooth capabilities?
No........
CS6319-4 Features:
  • New DECT 6.0 Technology
    - Interference Free Communication
    - Increased Clarity / Enhanced Security
    - Wider Range / Network Friendly
  • 1.9GHz Cordless Phone
    - Dedicated for Cordless Phones by the FCC
    - 30% Battery Life Increase Over 5.8GHz
  • Caller ID / Call Waiting
  • Expandable Up To 5 Handsets
  • Wall Mountable
  • Handset Speakerphone
  • Backlit LCD Display
  • Backlit Keypad
  • Name / Number Caller ID Memory
  • 100 Station Phone Directory / Dialer
  • Conferencing
  • Selectable Ringtones
  • Handset Volume Control
  • Handset to Handset Intercom
  • Call Transfer
  • Last Number Redial
Jun 03, 2011 | Vtech Lands Phones
How do i download music to my samsung champ?
What you'll need:
Bluetooth Enabled Phone
About 5 - 10 minutes (Depending on your phones Bluetooth speed and your patience.
Step 1: Powering on Bluetooth
First off, we will need to power your Bluetooth antenna on. To do this, please complete the following:
Go to the Main Menu (by pressing the Menu key on your phone
Go to the Settings button (usually looks like a wrench and screwdriver
Scroll down to "Connections" and press the Enter button (usually in the center of the multidirectional mouse. If you don't know what that is you can press "Select" on the top LEFT or top RIGHT buttons on your phone keypad).
Go to Bluetooth Link
Go down to "Setup"
Select Power
Make sure that there is a check mark next to the "ON" option
You may now press the END key on your phone (or close it and open it again)
# 4
Step 2: Sending the File
In this step, you will learn how to send a simple file (A graphic, Ringtone or Address Book entry. For this article we will learn with a Ringtone. Please note that you MUST have a Non-Motorola ringtone (so you can't use Cingular tune for copyright purposes).
Please follow these steps:
Go to the Main Menu.
Go to My Stuff
Go to Sounds (which may be labeled as something else)
Find the ringtone you wish to send.
Press the Menu button (Or use the appropriate soft key, or the key in the very upper left or right hand corner of the phone keypad)
Go to Manage
Go to "Copy" (NOT move)
Select Bluetooth
Go to Look for Devices (if it is not the only thing on the list)
It should display a message stating "Scanning" and under that "Devices Found: #". (# = Number of Bluetooth enabled devices in range)
After this is finished, select the phone by which you would like to send the file.
Press Select
Check the phone you are sending the file to and make sure it is sending properly. You may need to okay this from the other phone. If you are asked for a password usually
Tips & Warnings
Make sure you do this on BOTH Phones and NOT just the one you are sending the file from.
May 23, 2011 | Audio Players & Recorders
How do i send music from my LG P350 phone to another phone?
Hi, you can transfer music from your phone through blue tooth.
What you'll need:
Go down to "Setup"
Select Power
# 4
Go to My Stuff
Go to Manage
Select Bluetooth
Press Select
Tips & Warnings
May 23, 2011 | Cell Phones
How do I turn down the volum ring on the phone
Check for buttons on the side of the phone. There should be an up and down button to change the volume either way. If that doesn't work look for setting and then sounds. From there, it should be possible to find a way to change the volume of the ringtone.
May 05, 2011 | Cell Phones
I'm not able to send data via bluetooth to other mobiles
first make pair your mobile to other mobiles ..after that try to send via bluetooth ..
Sep 11, 2009 | Nokia N73 Cellular Phone
Volume control on the nokia 2600 how do you change the volume?
While on a call, you can adjust the listening volume by pressing left and right scroll key.
Mar 06, 2009 | Nokia 2600
Bluetooth for ringtones
instead of bluetoothing them use your beam option just go to the main menue and click on the menue key (it is a button) them go to beam that should work
Nov 15, 2008 | Palm Treo 650 Handheld
Motorola Mobility RAZR V3 Logo
64 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
