Question about Brother XL-3500
Brother bobbin tread will not pick up
I have a brother XL-3100 and when I try to sew the bobbin thread will not pick up. No thread at all is in the clothing ive just sewn. I have oiled it , rewound bobbin and changed needles. This is the first time i have used this machine (or any in last 15years) so i need help to know what im doing wrong or just haw to fix it.. Thank YOU HW
PS THE FRONT OF MACHINE SAYS ITS A BROTHER XL-3100, but this sight says this is not a valid product so i had to pick a difrent one to beable to submitte my question, again thank you..
  • faith26 Aug 07, 2008
    when i try to sew the thread gets caught up and the machine won't sew what do i do?
  • Anonymous Jan 29, 2009
    Same problem and I don't see asolution
    Master:
  • 539 Answers
Make sure machine is properly threaded, always put in a new needle of correct size for fabric you are sewing, and clean lint and any loose threads with brush from shuttle race and feed dog. Also, make sure you are placing needle thread and bobbin thread at least five inches in length under and behind center of the presser foot. Make sure feed dog in the UP position. I hope this helps as I have over 30 years experience and have never had to send any of my machines out for service. You can fix that machine!!! Even timing can be corrected, although that does not seem to be your particular issue. I hope this info helps.
Jimmy
Posted on Mar 29, 2012
When i sew the thread keeps cutting help
Posted on Aug 14, 2008
I have the same problem with the same machine!!! Did you ever find the solution?
Posted on Aug 13, 2010
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
How do I fix the stitching on my Brother XL-3010?
Your tension sounds far too loose. Or your needle is blunt.
Jun 25, 2015 | Brother Sewing Machines
Why Doesn't my sewing machine want to pick up the bobbin thread correctly?
if the bobbin case isn't turning properly are you sure you it in right.
Hold the lever on it out, slide the case on the spindle all the way and then release the lever. Also try a different length needle, it may be to long to allow a uniform stitch
Jul 12, 2014 | Brother CE8080PRW Limited Edition Project...
My Brother XL-5021 sewing machine has stopped working and won't pick up the thread from the bobbin.
it's called being out of time,,and the machine can only be timed by a sewing machine repair technican,, because they have the tools for job
Feb 01, 2012 | Sewing Machines
I am trying to use a twin needle, however, every time I begin sewing the machine makes a very unhappy sound as though the needle is being blocked as it tries to pick up the bobbin thread. I have tried ...
check to see if the twin needle are damaged
check the bobbin & make sure the bobbin case is thread correctly
needle & thread may not be compatable
here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 01, 2010 | Brother XL-2600I
Not sure if i have put bobbin back in correctly, I have an old janome sewing machine. Also I havent used a machine for about 10 years, trying to remember.
with the brother its Pretty easy. you drop the bobbin in with the thread heading counter clockwise take your thread around the feed guide in a Clock wise manner then turn your knob it should pick the tread up fairly easily
Apr 07, 2009 | Brother XL3750 Mechanical Sewing Machine
My Brother PE 150 will not pick up bobbin thread. I changed needles cleaned it etc. nothing helps.
My pe-150 embrodery machine is not grabing the tread right since I changed the needle out it keeps promping me to check my threading
Sep 07, 2008 | Brother PE-150V Computerized Sewing...
Brother XL-3500 Logo
539 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
