Televison & Video Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My television is just over 2 years old and it started that it would switch itself on and off 3 times before it would stay on and it was randomly switching itself on if I didn't need it to. I phoned the Samsung support line and they told me to reset the television which has only made it worse! It is now taking around 2-3mins to switch on and that is only IF it switches on. Then around 5 mins in it will switch off then stay on. Please help!!
Martin Murray
Level 3:
President:
  • Master 1,623 Answers
  • Posted on Mar 01, 2011
Martin Murray
Master
Level 3:
President:
Answers
1623
Questions
0
Helped
381868
Points
5205
There are four capacitors on the power board that the switch is connected to that are failing, eventually they will go completely and the set wont turn on at all. You need to replace the capacitors and the problem will be resolved. Find someone to replace them for you, they will cost less than £4 GBP to buy if you can do it yourself (or someone you know) probably over a hundred to get an engineer to do it
Raj Patel
Level 3:
Genius:
  • Master 1,042 Answers
Raj Patel
Master
Level 3:
Genius:
Answers
1042
Questions
Helped
270232
Points
3723
Your TV probably has a faulty power supply. Get it repaired before it gets worse and damages other components.
What would cause a model number 37wd12 to turn itself on and off at random.
Is the remote doing it?...remove the batteries from it and see if it still does that
My monitor is starting to go black randomly. I
1. are your drivers new?
2. possible from video card
3. try not to wiggle cords :)) it's not from there
4. try testing the monitor on other pc's/video board
5. if it work on other pc/video board then try updating your driver or refresh rate to low
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
1helpful
My 37'' Vizio Flat Screen TV keeps shutting it's self off
I had a problem with mine shutting off randomly and (luckily under warantee still) the guy came out and replaced the mother board. If you're under warantee still just call vizio.
Intermittent shut off
20 years is too long and the components ternmial might be loose or crack at this time, I'll susgest you look for any dry cold solder on the main board and do resoldering to the components terminal.
TV turns itself off
I currently work in teir 2 support for magnavox philips and this is a service issue i see alot on random sets hope this helps sorry fotr the bad news.. David
feel free to e-mail me with any other questions at [email protected] thanks.
Telly turns itself off
Hi there!
Have you checked for loose connection on the mains plug wires or perhaps a faulty mains adaptor. Otherwise it can be dry joints in the power supply or perhaps capacitors which have failed. If not sure refer to a repairer. Good Luck,JUS004
Tv switches off
set goes on 20 seconds it goes off
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
