Bush DVD142RC 14 in. TV/DVD Combo Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I brought this tv in romania and the sound does not work properly. only on dvd the sound is ok.
Anonymous
Level 2:
Sergeant:
  • Expert 158 Answers
  • Posted on Mar 01, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
158
Questions
0
Helped
21107
Points
502
What kind of cable are you using to watch TV, component or coaxial? If you have the option to try either, see if you can try whichever one you haven't yet to see if the sound comes through on the TV portion. Doesn't hurt to try different cables.
How do u connect up surround sound to my samsung tv
Connect the surround sound to cable box or use a optical wire
1helpful
My Polaroid 1911 TXLB 19in television is not working properly. The volume is very very very low. We have a DVD player hook up to it and its been working fine. Last nite was working, shut it off and today...
check the Sounds with Local TV channels.Is it still low?If it is still low sound circuit has to be repaired.if it is ok,sound switching circuit has to be repaired(TV to Video)
Sony KV-28LS36U problem finding programms and no sound
Make sure that in menu section on your tv, that you choose channel settings then the right setting are selected such as cable, air or whatever you are using in your area for receiption.
2helpful
No sound on TV
If the TV programs come's up with sound, then is possible that the TV set could be problem free. then cheek the system frequency if it need to be adjust from NTCS, PAL, AUTO MESECAM and so on. Cheek the DVD and VCR if they are in one of the following system settings and adjust the TV set to the settings at which the DVD or VCR is set to. Then you can also cheek if the cable is properly inserted, that is audio to audio and video to video. Nevertheless, if you have properlly connected your cables and set the system frequency to match with each other, and still no sound, then the TV could have sound problem.
Possible courses of sound failure in TV are as follows:-
1 RF stage
2 sound Ics or transistors
3 broken speakers
4 a break down resistor which supplie positive voltage to the sound curcult
DVD player makes clicking sound but won't play
check for proper connectionor check for playing another dvd. as every things seem to be ok.
Top Bush Televison & Video Experts
matt martin
matt martin
Sean Wright
Sean Wright
john h
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
