Question about RCA D52W19 52" Rear Projection Television
52" rca won't come on
What are the names or locations of the 3 capacitors?
  • RCA Master
  • 5,138 Answers
2200uf 16 volt /(2) caps 220uf 35 volts located in ( volt regulator circuit capacitors look Green with gold writting on them.
Posted on Aug 26, 2008
Tv won't turn on. It turned off after a few minutes and won't turn back on. We opened it up and replaced the fuse.Didn't change anything. A friend said that it just seems to not be getting any...
does the power light flash three times slowly then stay off? If so chances are its just the CP150, cp120 and CP114 capacitors. There is the RCA repair kit by that same name available from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
RCA -D52w20B It will not come on. B links 3 times for about 7 seconds each, with 3 seconds in between
thats usually caused by failed Capacitors CP150, CP120 and CP114. You can get the RCA repair kit by the same name from www.tvrepairworld.com which also has repair instructions included.
Oct 12, 2011 | Mitsubishi WD-52528 52" Television
When turned on the green light flashes 3 times. No picture.
replace CP150, CP120 and CP114 capacitors. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit contains the caps and the CD with instructions.
Feb 15, 2011 | RCA D52W19 52" Rear Projection Television
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
TV won~t stay on its blink three times then goes back off
CP150, CP120 and CP114 capacitors are the number 1 cause of that symptom. You can get the repair kit with that same name at www.tvrepairworld.com which contains those capacitors and the CD with detailed instructions
Jan 01, 2010 | RCA D52W23 52" HDTV CRT TV
52 in rca power light cuts on 3 times but wont power up what is the prob.?
The CP150, CP120 and CP114 is usually the cause when that happens. You can get the repair kit by the same name at www.tvrepairworld.com which has the capacitors and the CD with detailed instructions.
Dec 30, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA D52W19 52 in. Rear Projection Television. When I turn it on, the green power button light comes on and the tv sounds like it's coming on, then it sort of blinks...goes on and off a few times,...
The capacitors known as CP150 CP120 and CP114 often fail which causes that symptom. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Dec 30, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W23 52 in. HDTV CRT TV when i turn it on its on for 10 second and turns back on and off for 3 times then it stays off
Thats the CP150 cp114 and CP120 issue causing that. You can get the repair kit with the same name at www.tvrepairworld.com the kit contains the capacitors and the CD with detailed instructions.
Dec 06, 2009 | RCA D52W23 52" HDTV CRT TV
RCA Projection Screen - green light will light up but tv does not
There is 3 capacitors on your Deflection board cp150 2200uf 16v look and see if it is puffed up on top if so it is bad ,you need to replace other 2 caps as well cp114 cp120 both are 220uf 35v they will be green with gold writing on them.
Dec 23, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA 52 INCH. WILL NOT STAY ON. CUT ON THEN SHUTS OFF.
Check 3 capacitors cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v.they are green with gold writing on them located on deflection board.Rebuilt board 179.00 plus shipping union electronics
Look at top of caps if they are bubbled up on top it is bad replace all 3 caps.
Oct 12, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
32 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
