Question about Minolta magicolor 2350 Laser Printer
REPLACING CARTRIDGE Hi, Printing is low on yellow toner. Error light on. Can you replace just yellow toner
    Problem Solver:
  • 5 Answers
You should be able to replace just the needed color.  Select menu, arrow right until "Engine" is displayed, select, select "Replace Toner" select color cartridge desired. follow directions on screen.
Posted on Mar 25, 2009
Yes. Most likely the other toners will need replacing too.
Posted on Nov 19, 2008
How do i clear f2-73 after using program 88-6 how can i revers it back to normal
F2-73 refers to an improper yellow toner cartridge detected in your machine. The fault usually lies with the small chip installed on the rear of the toner cartridge.
The first thing to try is turning the machine off & then back on using the main switch inside the front door. The switch is located in the bottom left corner.
If that fails then you will have to replace the yellow toner cartridge.
If after replacing the cartridge, the error code re-occurs then you may have a toner motor supply problem. In my experience, replacing the relevant toner cartridge resolves the error code.
Hope this helps.
Dave.
Mar 07, 2016 | Sharp Office Equipment & Supplies
Hi mi sumsingcxs6345nis tuner error
See the section on Replacing the toner cartridge in page 10.3 of the manual.
When the toner cartridge is completely empty:
• Toner Empty, Replace Toner1 appears on the display.
• The machine stops printing. Incoming faxes are saved in memory.
At this stage, the toner cartridge needs to be replaced.Check the type of the toner cartridge for your machine. (Page 12.1)
There are many well explained steps in the manual.
http://downloadcenter.samsung.com/content/UM/200810/20081010120126000_Guide_EN.pdf
Mar 07, 2016 | Office Equipment & Supplies
Red light
Error Red On
• The cover is open. Close the cover.
• There is no paper in the tray. Load paper in the tray.
• The printer has stopped printing due to a major error.
• The toner cartridge is not installed. Install the toner cartridge.
• Your system has some problems. If this problem occurs, contact your service representative.
• The toner is totally exhausted. Remove the old toner cartridge and install a new one.
Error Red Blinking
• A minor error is occurring and the printer is waiting for the error to be cleared. When the problem is cleared, the printer resumes printing.
• The toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner.
Aug 03, 2011 | Samsung ML-2851ND Laser Printer
My orange light next to the yellow dot blinking and the printer will not print
When the orange light is solid it means the cartridge is low and you can still print. But when the orange light is flashing it means the cartridge is empty and the printer stops printing. To continue printing you will need to replace the yellow toner cartridge. The part numbers are Q3972 regular yield or Q3962A high yield.
Jun 23, 2010 | HP LaserJet 2550n Printer
Lanier 126cn keeps printing one page only and then it displays SC 363 error code. It freezez in this mode completely. Next time you have to power off and then back on in order to print another 1 page only....
sc363 is a yellow PCU error. Try replacing the toner cartridge and resetting the PCU. If the error comes back, you'll probably need to replace that yellow PCU.
May 12, 2010 | Lanier UNKNOWN
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Have amber error indicator light (blinking), and NO green indicator light; computer screen displays message "Yellow toner cartidge: Put"; I've removed yellow cartridge and replaced it and closed lid;...
It can be a faulty toner sensor, usually that happens when the printer is dirty inside. First try removing all toner, and preforming the complete toner loading procedure, refitting all toners on the carousel. If that does not work try cleaning the printer, see: http://www.google.com/webhp#hl=en&q=clean+printer+safely&btnG=Google+Search&aq=f&oq=clean+printer+safely&aqi=&fp=7sb--Tp2L2o If still no luck, then the printer is faulty. In that case call manufacturer at te number listed on the owner manual.
Jun 04, 2009 | Konica Minolta magicolor 2400 Laser...
Toner end life
it is printing with this blinking or not?
Jan 04, 2008 | Samsung ML-2510 Laser Printer
Yellow run out how can i still use printer?
Hi , You can try to do a disable cartridge check in the printer menu? But more than likely in order to get the full printing you might have to wait. Also you should check to see if the toner low message is set to on or otherwise when the printer runs out of ink it stops completly. Good Luck!!!
Nov 29, 2007 | HP LaserJet 3600dn Printer
Dell 1710
If that is the only light:
Remove the toner cartridge and firmly shake it from side-to-side and front-to-back several to use the
remaining toner, and then reinsert it and continue printing. Repeat this procedure multiple times until
the print remains faded. When the print remains faded, replace the toner cartridge
If not let me know.
Nov 16, 2007 | Dell 1700n Laser Printer
Minolta magicolor 2350 Laser Printer Logo
243 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
