Question about ViewSonic N3251w 32 in. LCD HDTV
ViewSonic TV sound but no picture
I have a 32 inch view sonic tv which had sound but no picture, is there a way to solve this issue, I have called view sonic but they were of no help.
thanks
Westcoastoo7
  • 2 more comments
  • dkomher Aug 24, 2008
    I have the same problem as westcoast.-NO picture(video) I have tried dvd's,wii game console,sound and no video.Using the remote(audio,change of channel,any menu) I should get video on the screen.Only get black.What else could be tried?
  • idn3o Mar 02, 2009
    the same thing here ...clules what to do with this
  • rinsko Mar 20, 2009
    son was playing ps3 he heard a sound and the picture went blank there is sound but you cant see anything and you cant turn off the game console
  • stuartt_629 Mar 20, 2009
    I have a Viewsonic 32" LCD n3246w. Until tonight it worked perfectly but now I get sound but no picture on the freeview channels. Anybody help?
I have same problem (power light is on, and I have sound, but no picture ) and found that a small capacitor on back of power supply is blown. Seems to be common problem. But viewsonic doesnt stock. Part number is b-00005352 and im trying to find one too
Posted on Sep 10, 2008
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: ViewSonic TV sound but no picture
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
Just bought a G-Sonic 32 inch sound bar came home hooks it up to my Vizio 42 inch tv no sound with bar??? RCA on TV and bar a PC and plug in no sound ?
I had the same problem, no sound from tv to the sound bar. I hooked up the output for sound from the sound source, your cable tv box or satellite receiver and ran it to the sound bar, and then received sound.
Nov 29, 2013 | Televison & Video
View Sonic TV wont power on
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 25, 2012 | ViewSonic N4060w 40 in. LCD TV
View sonic flat LCD TV 32' turns power off.After charging cable is disconnected it worksfor a few seconds but turns off sfter that
You will need to open it cant fix it from out side better bring it to a technical center i can give you advices what to do when you got it open but i`m not edvising you to do this if you have no soldering skills
Sep 24, 2010 | ViewSonic N3735W 37 in. LCD TV
POWER ON ISSUE IN LCD
I do not know where service center is, but at least you can tell them what to look for: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
Apr 01, 2010 | ViewSonic VA721 17" LCD Monitor
View sonic 32 inch lcd tv has purpleish tint where black area used to be
ther is a problem in vertical area,just a capacitor only must be replace.
Jan 04, 2010 | ViewSonic N3251w 32 in. LCD HDTV
My view sonic monitor does not work properly
sounds like the power supply inside of the monitor is going bad. did you replace the cable from tv to the wall?
Oct 16, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Lost some stations on my Sony lcd TV.
It is most likely a signal issue. Bad coax connections, splitters and faulty cable are usually the culprit. Best to call your cable company and request a signal test. You may also try swapping tvs. Swap sony with viewsonic in the room where viewsonic tv is.
Jul 03, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Mar 20, 2009 | ViewSonic N3251w 32 in. LCD HDTV
No Picture on Viewsonic TV
Had a problem with 32'' viewsonic.No picture and had sound.Fix is a chip on power supply($15.00) part.I replaced and all ok now.
Jan 11, 2008 | Televison & Video
3 inches missing on both sides
Sounds like it is a widescreen TV stuck in standard view mode. Should have a menu option called widescreen or movie format.
Do you see the whole picture squeezed down or is it actually cutting off the sides of it?
Jan 08, 2008 | Proscan PS32125 32" TV
ViewSonic N3251w 32 in. LCD HDTV Logo
2,053 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
