Question about Lenovo ThinkPad R51
Usb port i constantly get a bubble saying that the usb device not recognised it has malfunctioned.the thing is that it'd be different if a device were connected.its empty n i keep getting the bubblen then i connected my ipod n it shows unknown device in the device manager,pls help
  • Anonymous Feb 23, 2009
    i have same problem. It said usb not recognized
    Problem Solver:
  • 28 Answers
Idk about that one. i have never had a problem like that.
Posted on Jul 30, 2008
Why when i plug the MP3 player (YP-T10) into the computer, the computer says 'One of the USB devices attached to this computer has malfunctioned, and Windows does not recognise it'?
Here are a few things you can try:
1) Plug it in to other USB ports of your PC/laptop. The port might be faulty. 2) Replace the USB cable 3) Download the latest driver from Samsung's website here:
http://www.samsung.com/my/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=YP-T10AB/XME&srchword=YP-T10
Click on "Downloads"
Mar 07, 2011 | Samsung YP-T10 Digital Media Player
Hi i have an everio gz-mg 135 and when i connect it to my pc to back up files the message "usb device not recognised. One of the usb devices attached has malfunctioned. Windows does not recognise...
- Make sure you have been installed JVC driver on your PC - If your PC has multi ports USB, just try other ports to make connection - check your firewire, it may be malfunctioned . Try other USB cables
Jan 16, 2011 | JVC Everio GZ-MG130 Camcorder
When I attach the camera to the computer it says the USB device has malfunctioned and Windows does not recognise it. This is a brand new camera but does not seem to be working properly. What should I do?
this is a problem that occurs whenever you connect your external usb device to a port that is not capable of handling the device. for example, your camera might require a usb 2.0 port to operate and you may be connecting it to a port that is not a usb 2.0 port.
what to do is this, try connecting it to different ports on your system and see if that helps you.
if it doesnt then you can try connecting your camera to another computer and see if it works. if it does on another computer but not yours, you have to update the drivers.
you would need to call an expert or the manufacturing company to obtain instructions on how to update the driver.
hope this was helpful?
Dec 30, 2010 | Sakar Kidz Cam Digital Camera
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
USB device malfunction
i) try to connect pendrive to the usb ports present at backside of ur computer tower instead of usb ports present at the front panel of ur computer...............
ii) sometimes usb ports present at the front panel ofur computer might have loosen connections............
Thanking you
M. Sridhar
Jan 18, 2009 | Intel Motherboard
Usb malfunction
The USB ports have gone bad. Just because they show up in device manager as being recognized does not mean they are working correctly. They are controlled by chips onthe motherboard and if one of those chips has gone bad, then they just won't work. The cheapest solution would be to purchase a USB card and install it, bypassing the onboard ports. Thanks and please take a moment to give this solution a rating of fixya. Thanks! :c)
Dec 29, 2008 | Intel Motherboard
Usb not recognised
Hello ak1979 ...
1. You're plugging in your Transend USB flash drive to your computer's USB port (as you've done many times successfully before with this SAME flash drive)?
2. It says "windows not recognise usb drive due to malfunction"?
a. Is that EXECTLY what the error says?
b. Is "it" an error dialog (window that pops up), or an error message from your Windows Event error logs? If a dialog, are there any pertinent error message entries in your Windows Event (System) log [Start > Run > type "eventvwr.msc" (without quotes), then "OK"]?
Try a bit of deductive troubleshooting:
  1. Restart (Reboot) your system [for a fresh start, if you will].
  2. Try plugging in your USB flash drive again, but in a DIFFERENT USB port.
  3. Try plugging in ANY OTHER "known good" USB device into the same USB port(s) used thus far that failed.
NOTE: If you EVER get any indication Windows recognizes the flash drive (like no error msg, or it shows in "My Computer"), IMMEDIATELY perform a "Check Disk" on it:
  1. Start > Run... > type "cmd" (without quotes), then "OK".
  2. Type "chkdsk DRIVE_LTR: /f" (without quotes), then hit "Enter" [where DRIVE_LTR is the drive letter of your USB drive]. EXAMPLE: chkdsk E: /f
Good luck, and please post back:
  • to provide any corrections/updates/clarifications.
  • if you have any further questions.
  • to let me know how things work out.
"Today's the best day of my life...and NOW you're part of it!"
Dec 24, 2008 | Transcend (589307) Media
HELP!!!
Try a different USB port if you have one.
May 12, 2008 | Apple iPod nano
Archos 605 usb connection problem
its possible you could have picked up a virus that is making unauthorized changes to your pc. happened to me. had to reboot pc to original factory settings.
Jan 27, 2008 | Archos 605 WiFi Digital Media Player
USB device not recognized
Try uninstalling windows version of bluetooth, then re install your adapter driver from the cd, but try in a different usb port.
Jan 17, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
Computers & Internet Logo
374 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
