I have a noise coming from the left side front wheel are. It is a rattle - took it to a local Toyota dealership who said it was the steering RAC well that was a $1000 mistake because the noise did not...
1) Take car to non dealer shops willing to give FREE opinion
2) Not likely you have a shock in Driver Front wheel, more likely a strut. Not likely strut needs to be replaced, but strut has a STRUT MOUNT (3 bolts of which can be seen when opening your hood) below this it is connected to STRUT BEARING which below it connects to UPPER SEAT OF STRUT or SPRING INSULATOR, that if loose will rattle. Usually, shops will not tighten, because to tighten is same labor as replace the parts. (Since you already dropped $1000 on ToyotaDealer, ask them to tighten FOR FREE since rattle is still there.)
3) There is a part called a "link," connects strut to stablizer bar, that if bushings are bad will rattle.
4) If stabilizer bar bushing(s) bad, will rattle early on but eventually clunking
5) Bad ball joint or tie rod can rattle as well
Never permit any shop to do expensive work on your car w/o first getting a second opinion somewhere else first. Do not tell second shop that you are there for a second opinion.
Shaking steering wheel at highway speed, no braking
1) Bad tire in front, bad tires in front, verify inflation of tires
2) Wheel alignment may be out
3) Front suspension parts (mentioned several above)
Highway speed to suddenly braking shakes steering wheel
1) Front brake rotors need to be inspected for warping
2) Test calipers on empty road at 40 mph, going straight on very LEVEL ROAD, hit brake pedal SOMEWHAT hard while barely touching steering wheel. If car jerks to one side, instead of braking straight on, you may have a caliper, ABS, or brake fluid pressure regulator off.
3) If brake rotors are warped, may as well replace front brake pads at same moment. Use ceramic.
4) When you drive on VERY LEVEL road on highway, steering wheel must be centered, let go lightly of steering wheel. Did car stay in middle of lane? No? Get a 4-wheel alignment.
Just bought 2003 Navigator has a same problem
You simply need to change your 2 front ROTORS and 2 front BRAKE PADS. That will definately solve your problems.
the steering wheel shakes and I start to loose power. the only way to fix the propblem is to pull over reeve the guts out of it. i may need to do this several times befor it comes right.
Steering wheel shaking when braking
shakes when i slow down and when i reach the speed of 55mpn when I take foot off gas pedal it stop shaking.
could it be a wheel bearing
