Question about Bosch Dryers
Bosch classixx condenser dryer how do get to reservoir as its not pumping water up to condensing drawer
Pay me, I tell you. I am an Engineer, why work for nothing when we can rip you off, and take OAP life savings for a simple fix ; )))
Posted on Mar 06, 2009
Bosch maxx 7 sensitive dryer wich stops everytime and shows that there is a problem with the reservoir
Technician just solved that annoying problem. My dryer is few months old and without pump, so condensed water is dripping to tank by gravity. During drying cloth is collected on filter and condenser, but some amount of cloth goes into pipes and canals on the bottom of dryer and clogged non-return valve where tank is inserted. Side panel ha has to be removed, canals and valve cleaned. To prevent problem technician suggested condenser and filter cleaning after every use. Valve can be removed from bottom without removing side panel.
Dec 18, 2010 | Bosch Dryers
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Dec 22, 2009 | Bosch Axxis WTL 6003 Electric Dryer
Bosch classixx condenser dryer won't turn on
try replacing the thermistate fuse link
Dec 04, 2009 | Bosch Axxis WTA4400 Dryers
Bosch wtl 4110 dryer not condensing. Hose is not clogged.
when you say not condensing I will assume you mean not getting hot enough during rinse cycle to dry dishes with condensation.
Check out comments and replies at this link:http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
Nov 01, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Bosch WVF 2402 Washer Drier Steam Problem
Hello All
Problem solved by clearing out the condensate container which on inspection was full of dried up fluff and dead tissues! This is not a ****that is mentioned in the manual and access to the bin is pretty tricky so I suspect there are lots of machines out there with the same problem waiting to happen.
Access was gained by taking the top of the machine off, removing the dryer motor and then scraping out the muck using a wire coathanger and a vacuum cleaner.
Many thanks
Andy Wray
Mar 08, 2008 | Bosch Classixx WVF 2402 Front Load...
Steam coming out of washer drawer
This problem happened to us too, fortunately it's quite easy to repair. The problem may lie with the water inlet solenoid (rear of machine, top left under the top cover). The cold water inlet to condense the steam may not be working correctly and the steam comes out of the detergent drawer. Replace this solenoid (bank of three on the water inlet) and this should solve your problem.
Jan 27, 2008 | Bosch Classixx WVF 2402 Front Load...
Dryers Logo
727 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
