Hi sherri you are sure the connection the rear Audio/input is in the right location and the menu should have a selection under the menu/title that is a mute function
try this originally posted by gt3rs i just did it and it worked for me
Here is a solution that worked in my case (constant reboots after voice select)
Plug your tomtom into your PC.
Run TomTom Home
Select the option to run your TomTom through your PC (TT Home)
You should be greated with the select language screen
Then simply select language etc.
When you get to the voice selection: select a voice (here TTHome should freeze) <- also strangely enough notice the cancel button doesn't on the screen (as it does when doing this on the device)
Don't panic TT Home should start working again in a few seconds
Disconnect your TomTom and that should have solved the problem, the normal map screen should show up upon starting up your TomTom
This solved the issue for me, hope it does for you good luck!
you will need to pair the parrot with syncro disabled, try setting/ pair with phone/ disable syncro. this will stop asking the LG for the phone book, you will then have to send the phone book entries one by one.
there are a few phones that garmins dont work with try software updat from www.garmin.com and samsung, if not that connact garmin and ask if they know of this problem
the gps extracted the information from your phone. so its the phone whichs needs the editing, the gps will not update till that number calls you again, remove not drop the connection from your gps and phone after you have edited phone book re-pair phone should update when address book transfers
