Linksys Wireless-G WRTP54G Router Logo
Anonymous Posted on Jul 29, 2008
WiFi Signal Strenth
Wifi Router is at one end of the house. PC is at the other. I Would like to put a signal repeater in the middle of the house, What should I buy?
PS: The product I entered below was just so I could post it. I don't think it will do the trick.
  • 1 more comment
  • Anonymous Jul 29, 2008
    Yes, from one end of the house to the other I end up with oe or no bars. A repeter sounds like what I need. So it is called a WiFi repeater, is that correct?
    Without typos
    Yes, from one end of the house to the other I end up with one or no
    bars. A repeater sounds like what I need. So it is called a WiFi
  • Anonymous May 11, 2010
    is there a need for repeater? what is the signal strength without it?
mohana sundaram
Level 2:
Novelist:
  • Expert 173 Answers
  • Posted on Jul 31, 2008
mohana sundaram
Expert
Level 2:
Novelist:
Answers
173
Questions
0
Helped
98892
Points
285
Yes of course you are correct, you need a range extender, which will boost up your signal strengeth..you can purchace one according to your router standards, you can go for linksys range extenders..but select the proper one which works perfect with your router..
Weak wifi signal?
you have 2 possible solutions:
the easiest (but suboptimal) is to put buy a wireless repeater and install it half way between your access point and the point where you experience low coverage.
Amazon com NETGEAR N300 Wi Fi Range Extender Essentials Edition EX2700...
the best solutions is to buy a power line kit like this:
Amazon com NETGEAR PowerLINE 1000 Mbps WiFi 802 11ac 1 Gigabit Port...
you can plug the one without the wifi to a power outlet near your wireless router, and connect the two devices by a network cable. then you can plug the second powerline (the one with the antennas) in a power outlet near the place where you need wifi signal. the second device needs a little configuration (just put same network name and password of your old access point).
this way you will have your a new wifi access point, that will connect to your internet connection by power wires in your house.
tip
Boost wi-fi signals!!!
It is true that a direct cabled connection is probably faster, but that doesn't mean you can't get great Internet connection speeds from a WiFi connection. WiFi is a signal, so it's simply a matter of boosting that signal to extend as far as you need it to, and doing it in a way so you'll still get the same amount of power. There are ways to extend your WiFi signal, and most of them won't cost a penny. Here are my ten ways to boost your wifi signal:
  1. Position The Router - Yes, where you place your router does matter. If your wireless desktop or laptop is in another room, the signal has to go through walls and other interference before it reaches you. You can change the positioning and give everyone equal access. For example, in an open office room setting, instead of placing the router in a corner, try putting it in the middle of the room. It might give better coverage to the entire office. The signal should extend out more evenly. If you're looking for optimal wireless coverage in various parts of your home, position the router in the middle of the house. Moving it up off the floor, to a bookcase or shelf, should also help. If you only have one wireless computer, and it's always in the same place (ie: your office, the kitchen, or the hammock) then it makes more sense to place the router closer to the computer, rather than in the center of the house. But experiment -- I've heard of cases where there was a very weak signal, and the problem was that the router was TOO close to the computer.
  2. Avoid Bad Neighbors - Remember, wifi is a radio signal, so the signals from microwave ovens, cordless phones and even your neighbor's wireless router may interfere. So try to steer clear of those as well.
  3. Extend the Antenna - There are some decent booster antennas out there that you can purchase in addition to your current router to help the signal extend out further. You just plug them directly into the router base and it can give you that boost in the signal that you need. Hawking makes several types of wireless antenna boosters.
  4. Repeaters - This little gizmo just takes in the wireless signal, boosts it up to full strength, and spits it back out again. Place the repeater within range of the router, and near the computer that needs a wireless signal. Linksys and D-link offer wireless repeaters, also called range extenders. If you have an Apple computer, look into the Airport Express as a signal repeater.
  5. Gettin' Geeky - Some DIY geeks have come up with interesting ways to extend or boost your Wi Fi signal. One example is the Pringle Cantenna method. This may seem like a hoax, but the technique appeared in an O'Reilly book titled Building Wireless Community Networks, Nov. 2001. Other techniques, such as the satellite dish using a cellphone are elaborate hoaxes, and I'll admit I fell for this one before a kind reader set me straight.
  6. Upgrade Your Router - If you've owned the same router for several years, it might be good to go pick up a new one if you want to expand your connection. Some of the latest models have a stronger signal. The newer 802.11n routers generally have a stronger broadcast signal, and they'll work even if you have an 802.11B or G adapter in your computer.
  7. Upgrade Your Software - One of the most basic things you can do is to make sure your router software is up to date. To do this, visit the website of the maker of your router, whether it is Linksys, D-Link, or some other brand. Check for your model number and make any updates necessary.
  8. Tweak Your Settings - Your software has special features that you may or may not want. Make sure you read the manual that comes with your router and tweak it to fit your needs. Most modern ones are "just plug it in" though there might be ways to boost signals or to make sure it is sending out signals that are optimized for your computer's wireless adapter. For example, most routers are set to broadcast on channel 6. Try switching the channel to 1 or 11 and see if it makes a difference.
  9. Is Your Wireless Router Secured? - Make sure your neighbor isn't hogging all the juice from YOUR wireless router. Get your network secured only you are using the signal. Tap into your security features and make sure you use secure passwords. See wireless security for help with this.
  10. Find Alternative Firmware - While your router's original software (aka firmware) should be all you need, some routers do not output the signal at the maximum possible strength. You might want to check into alternative firmware, like OpenWRT. But be careful with firmware updates -- if you load the wrong code for your router, you can foul it up with no recourse.
on Jul 20, 2010 • Computers & Internet
Dap 1360
1- first distance between Dap-1360 from the router wifi Nilox should be max the signal length around 50 meter,
2- try to update the Dap-1360 software from the internet then test the network cable again and the electric cable..
hope it help ...
D-LINK DI-524 coverage Issue
You can reboot ALL the devices . Unplug the Modem, remove battery, Unplug the D Link. Install battery in Modem, plug into AC, allow the device to selftest, plug in D Link allow it to self test. Reboot computer. Have you secured the wireless? Changed Channels for better signal? Take a look at this: http://www.microsoft.com/athome/setup/wirelesstips.aspx#fbid=nZTFiYrDLMg
Is there a WIFI Signal Booster out there for a Westell A90-750015-07 Router/Modem?
you don't need a signal booster. Instead what you need is a WIFI signal repeater. This device basically captures your router's signal and repeat it to other devices. Basically place is somewhere between the router and your computer.
There are many out there but here's a cheap one on ebay
http://www.ebay.com/itm/like/122201090687?lpid=82&chn=ps&ul_noapp=true
We have a router so that we can have wireless connections in the upstairs of our house. The connection shuts off every 20 min or so. Do you know a solution?
Have you tried moving the computer upstairs to a different place to get the best signal ?
What is the signal strenth?
Have you tried moving the router to a different position?
If your signal strength is quite weak, you may need to get a more powerfull router, like this one http://bestofferbuy.com/2.4GHz-1000mW-High-Power-802.11b/g-WLAN/WiFi/Wireless-Broadband-Router-p-50909.html?currency=GBP&utm_source=gbase&utm_medium=cse&utm_campaign=gbase
they are about twice as expensive.
When i lock in the http/:192.168.1.100 aroung my house i can get throught but when i at out side the house i cannot get throught
it might b due to less wifi signal..
use aluminium foil ..
make a cardboard type structure of aluminium foil.
and keep in the router,
it will increase ur wifi signal.. also try easywifi software
it automatically detects the wifi near u and incerase the wifi strength of u pc
1helpful
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Actiontec Model GT701-WRU signal failure when on line when using notebook in other parts of the house no signal to desk top pc on third floor of house signal to low disconects from the net can you...
That is not a configuration problem, that is a signal problem.
It means that the signal does not have enough power to reach all part of the house.
A way to fix this is by installing a repeater, like this one Linksys WRE54G-UK 54Mbps Wireless Range Expander
Your router is a G, not very powerful. An alternative is buying a more powerful N router, like the ones below.
www.newertech.com/products/router.php
BELKIN B5DUK060 Router + WiFi 802.11n USB
Se the comparison diagram
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
