Setting timer for Unidaire nightstore heater
How do I set the timer? It has a 24 hour circular timer on the wall with small plastic teeth that you can push towards the outside of the dial or towards the centre of the dial. I assume that this determines when you are drawing power from the grid. I'm not sure which way to push these teeth(ie inwards or outwards) so that I get night power only.
  • tanner503 Aug 13, 2008
    excellent thank you-just what I needed
Little triangle to the left 9 o clock position determines what time it is, set actual time to this, then move outer dials to turn on and inner dials to leave off, and then set to auto, this is in timer mode, other mode is permanently on and off..
hope that helps
steve
chch
Posted on Aug 12, 2008
GE plug in mechanical timer model 15417
Copy following links to identify timer and setting analog timer by experimenting with features.
GE timers change appearance as model numbers are upgraded, but all 24-hour analog timers have same basic features.
http://waterheatertimer.org/GE-timers-and-manuals.html#15119
http://waterheatertimer.org/How-to-set-timers.html
Sep 23, 2012 | General Electric Ge 24-hour Mechanical...
I want to reset the timer for hours of on-off for out water heater but can't figure out how to push the little white teeth in or out. Model is 265-1.
1) Open following link to read about re-circulation systems:
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) Image below show typical FM1 analog timer dial with pins:
Move pins with fingernail or small tool.
To test if pins need to be moved in or out, set pins each direction and manually rotate dial clockwise and listen when pump turns on-off.
How timer operates: clock motor rotates dial continually, pins on dial move lever that turns circuit on-off.
To set current time, manually rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Some timers have a selector switch: move switch to Auto, or Timer, or Timer ON. Again you can manually rotate dial and check which setting is correct.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 14, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
Programing
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
http://waterheatertimer.org/images/6124-manual.pdf
If you have different timer, look at link below to help identify timer.
Leviton Timers:
http://waterheatertimer.org/Leviton-timers.html
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Dec 02, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
I have ge model 15119 24 her timer and need help on how to set
GE 15119 timer is a 24-hour plug-in dial-type timer.
Dial rotates as time passes.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
Plug timer into wall.
Dec 01, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Lost instructions on how to set it
If I understand correctly, you have an indoor timer
Your timer is Woods brand. (other brands may program differently)
Your timer has a circular dial on the front. (other types of timers do not have a dial, they has a digital display)
Your timer plugs into the wall -or- it is installed in-wall where a switch goes.
Here is a photo that might help.
To set current time, you rotate dial until is lines up with the triangle shape located on inner dial.
If this is not your type of timer, please answer in return and we'll get your timer going with information that is accurate to your model.
Push pins in and out to control ON OFF functions.
If your timer plugs into the wall, then it will not have the manual override slider switch shown above.
Oct 21, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
http://waterheatertimer.org/pdf/Woods-59203.pdf
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Release clock button
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
Oct 17, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers offer 7 day function with more programming choices... which may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Decora 6124H Timer
Jan 04, 2010 | Leviton 6124H 24 Hour LCD Programmable...
Heating & Cooling Logo
255 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
