Question about Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L
Bosch sliding miter saw, the bearings in the slide mechanism are catching making a jerky slide, have tried wd40 any ideas?
    President:
  • 1,996 Answers
Have you tried blowing out the mechanism with a compressed air nozzle? Frequently this friction is caused not by the bearing itself but instead by debris, sawdust, etc. built up inside the base of the saw. I'd give it a good cleaning to begin with.
If that doesn't work, try applying bearing lubricant directly to the bearing races.Use an extension straw if needed so you can get to them, as this is designed to penetrate where even the reliable old wd40 may not reach. You can find this a specialty woodworking stores, as well as some well-equiped home centers.
Let us know if this works, or you've already solved the problem...
Posted on Mar 25, 2009
Makita 10" dual slide compound miter saw jerky while moving in and out. What,s wrong?
The pillow block bearing, guide bushings, or even the slide lock mechanism could be the culprit.
If you post the model number I can help narrow it down for you.
Feb 15, 2017 | Makita Saws
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
The belt on my new saw started to frey after some use
It sounds like you need to replace the belt. try the following websites, they offer the saw parts:
http://www.ereplacementparts.com/bosch-5312-dualbevel-slide-miter-saw-parts-c-128_1090_157465.html
http://www.toolpartspro.com/bosch-parts/bosch-5312-parts.html
Feb 10, 2013 | Bosch 5312
Slide mechanism is stiff
linear bearing problem
clean them with brake cleaner and compressed air
the balls should roll freely in the grooves inside bearings
push balls into the slots with compressed air to remove the dirt and then a little bit of oil and it should work.
Nov 23, 2012 | Makita 10" Dual Bevel Sliding Compound...
My 10" Bosch miter saw
I would remove the blade and try the saw again, there is a possibility that you might have gotten a flange on incorrectly or left the spacer out.
Sep 10, 2011 | Bosch 10" Slide Miter Saw
Blade stops in middle of cut, slipping motor rpm is un changed. 10" compound sliding Bosch miter saw
Going on the information aas I read it, the blade is slipping, meaning that it is not tightened enough or a spacer in the hole in the blade is too thick. Make sure that the wall plug is pulled out before attempting any work on the blade.
Jan 16, 2011 | Bosch 10" Slide Miter Saw
I need manual for kobalt sliding miter saw sm2505lw
Call-18883Kobalt and they should be able to help you. Listen for the prompts to make sure you get the right service agency for miter.
Sep 15, 2010 | Bosch 12" Compound Miter Saw 3912
Bosch gsm 10 compound mitre saw. which way does the screw turn to undo blade
On the Bosch compound sliding miter saw, turn the blade nut clockwise to remove it.
Jul 26, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L Logo
184 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
