Bracelet I need to buy a new bracelet black rubber for tissot race. could you send some shop or techinnical assistance, that I can do it buy Internet with delivery in Brazil Valdemir Souza [email protected]
i dont know where is the service center of tissot T-touch i need to replace the battery i'm from manila philippines.This is the first time to replace the battery so i need the service center can you help me?i dont know where is the service center of tissot T-touch i need to replace the battery i'm from manila philippines.This is the first time to replace the battery so i need the service center can you help me?
You can't post conmments that contain an email address.
Srevice center for tissot watches here in the philippines is only at timeline...g/f farmers plaza cubao,q.c. its fronting gateway and araneta coliseum.
may i know where is the service center of tissot watches in the philippines i'm in manilamay i know where is the service center of tissot watches in the philippines i'm in manila
mcdevito75 here, Ebay is a great place for your Tissot watch band, or you can check with any small watch repair shop in your area, specially if you want a band directly from Tissot.
Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
Step 2
Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
Step 3
Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
