Question about Philips 46PP9302 46" Rear Projection Television
Ic part numbers
The part number is STK-392-120. Is one red and one blue? Any way to tell. Thanks in advance for your help Dan!!
  • 4,234 Answers
See the initial question thread for the response. I'd rather keep the dialogue there.
Thanks,
Dan
Posted on Jul 29, 2008
Attention, SD TECH I read your 8/25/10 post on
This model does not use STK CHIPS. Look on back of set where model number is---what is PTK number---ie: PTK 169, OR PTK 195
Sep 01, 2010 | RCA P61960 61" Rear Projection Television
Hi sir greetings can you tell me stk output ic number as someone has removed it hoping you can help me thanking you ...
There is a good possibility that we can assist with this, but we need the make and model of the unit in question. Please update this with that info and we'll provide the part number.
Thanks,
Dan
Aug 29, 2010 | Audio Players & Recorders
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Samsung three colors on screen, out of focus #hcl4715w
It is a convergence problem. The IC's (integrated circuits) or STK chips or the "guns". You have a red,and blue, IC's that provide all the colors. When the colors are out of convergence, you get ghosting or what looks like 3D pictures. I haven't been able to locate the part numbers for the IC's or STK chips but have located a convergence board. No luck determining if IC's are included (a phone call first to verify) but if they are, would make life much easier for you to install. Part # is BP95-00415H http://jr.partsearch.com/Part/Samsung/Samsung/BP9500415H/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HCL4715W
Typically, IC's cost around $10 or less. here is a link to a guy who provides pretty good instructions on replacing the IC's along with pictures.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Hope this answers your questions. Best of luck.
Greg
May 31, 2009 | Samsung HCL4715W 47" Rear Projection...
Samsung HLM507W 50 in. STK IC's
STK-392-180s these are the best.Replace BOTH
Feb 01, 2009 | Samsung HLM507W 50" Rear Projection HDTV
Red out of focus
You red convergence IC is bad, Have the Convegence IC's replaced,It would be wise to replace them both because if the red has failed then the green/Blue IC will fail soon too. Better to replace them both now then have to do the same again with the other IC.
They are large black IC's mounted on a metal heatsink with part numbers on them the Number on them is the part number should be STK-392-040.
Dec 17, 2008 | Samsung HCN5527W 55" Rear Projection...
HITACHI ULTRAVISION 60" COLOR NOT IN SINC
Look for the board that has 2 big black ics with STK printed on them.
Dec 09, 2008 | Televison & Video
Red bows and wont realine
Replace the red AND blue convergence IC's. Both need to be changed. You change the blue IC to ensure your repair will be reliable. They are mounted to large. finned heat sinks because they get very hot..hence why they fail more often than any other part in a projection tv. The # on the chips will start with "STK-" followed by numbers. These IC's are available through tritronicsinc.com. They cost about $15 to $35 each. Good Luck!
barneyluc
Oct 07, 2008 | Toshiba 57H83 57" Rear Projection HDTV
50h82 red convergence ic replacement
Q783 is a 2SJ512 (FET) with part number 23205037. These are not the easiest to test. If you suspect that it is bad, just replace it. It costs $2.48. I only have a listing for one convergence IC (STK-392-110), but if there are 2, replace the one labeled RVBVGV or just swap the two to see if the convergence shifts from vertical to horizontal.
Keep us posted.
Dan
Apr 17, 2008 | Toshiba 50H82 50" Rear Projection...
Convergence problems
I would suggest the convergence ICs as well as a couple resistors right near the Convergence ICs mst likely. 90 % of the time thats the problem. They are not expensive, if you can solder you can handle it if your careful with your solder and use heat sink compound. The ICs will have a number stamped on them usually STK XXX-XXX on a huge heat sink. The following link will have replacement parts http://electronix.com/ Hope this helps you out
Jan 11, 2008 | Panasonic PT-47X54 47" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
