Question about GE Lands Phones
Purchased 2 ge phones model 29585 installed and ok for several days.now when picking up receiver to dial out we get a pulsating busy signal for a few seconds and then the dial tone and are able to dial, what should we do to correct this.
That sound is notification of voice mail. This phone does not disconnect incoming calls on answering machine extension so your phone is actually off the hook for hours without your knowledge.
Posted on Oct 11, 2008
Dial out always busy
View topic - Fast Busy Signal when Calling out - Ooma
www.ooma.com/forums/viewtopic.php?f=4&t=13773
May 15, 2012 - I'm out of town, but yesterday I tried calling a few numbers and alwaysgot the fast busy. Incoming calls were fine. I rebooted the telo and it still ... Can't Dial Out To Same Area Code
Feb 4, 2014
Can't dial out
Dec 3, 2011
Can't make calls, can't receive calls, but I have ...
Sep 13, 2011
cannot dial out and dial in
Nov 1, 2010
More results from www.ooma.com
Jan 26, 2016 | Cell Phones
Hello...The base of my Uniden D1384-2 does not seem to be communicating with the handsets. Handsets are fully charged and all functions work. The base unit lights work and are capable of charging the...
it might be because of interference. i think it takes all the power from your other phones cause it needs all the power from your other things plugged in to try to get rid of the problem. if this helped, good. if it didnt, sorry. the way to solve this is to probably look at the base and figure out how to open it and take a look inside.
Aug 09, 2013 | Uniden Lands Phones
Panasonic KX-TCD220E - pulsating busy signal for a few seconds then dial tone
If that pulsating tone is anything like what I sometimes here on my phone, then it has nothing to do with your phone. It's your telephone company telling you that there's unheard voicemail on their system. You'll need to contact your telephone service provider for instructions on how to access their voicemail system.
Apr 10, 2012 | Panasonic Lands Phones
My Radio Shack Digital Telphone Answering Device TAD-3829 worked well for a little over a year. However a few days ago I discovered that I cannot receive incoming calls anymore; on the callers side there...
These 3829's do that often. After about 1 year or so of use, something fails internally, resulting in the symptom you see. Sometimes you get "Er" on the display, or the machine simply won't pick up and answer the call.
Bottom line - this model's not very good. Ditch it.
Jul 02, 2011 | Radio Shack (43-3829) Digital Answering...
Avaya / Lucent MLS-12D Partner MLS12D Display Phone - BLACK: when A user picking the Avaya phone up, user don't...
get more lines.
Or check Auto line select.
From ext 10 or 11:
press feature 00
press left intercom twice
press right intercom once
enter extension number
press **
then press the lines in the order you want them picked up (line 5, 4, 3, 2, 1 then the intercom )
press**
press feature 00 to exit programming.
When the extension picks, it will pick up line 5. If 5 is busy, it will pick up line 4 , etc....
May 16, 2010 | AT&T Lucent MLS-12D Phone
Model 28128 dials cell numbers OK but not landline numbers
this issue is likely with the uverse equipment. try to unplug your gateway (the modem) and plug it back in. if that doesn't work then call the uverse tech support. They are open 24 hours a day.
Sep 11, 2009 | GE 28128EE2 Phone
KX-TGA110FX
1.Press (ok)
2.Arrow down(twice) to "setting BS" then right
3. Input PIN code.Usualy 0000
4.Press "1"if you want TONE dialing or "2" for PULS
5.Press right arrow,then on/off button
Oct 30, 2008 | Lands Phones
Cannot receive faxes
1-are you sure it is in the correct jack? there are two in the back of the printer
2-when you did the install it should have done a fax line check
Sep 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Dialing out
Usually picking up the handset and dialing " 9 " will get you another dialtone and then you dial the number you want. If you receive a busy signal it could mean your system requires another number to dial out or your phone is restricted from dialing out. When you pick up your handset or press the INTERCOM key you should get a triangle shapped light which means you can proceed with dialing your access code for making a call ( 8 or 9 ). Hope this helps, let me know ...Mike
Aug 17, 2008 | Nortel T7316E 2-Line Corded Phone
No dial tone, clicking sound
It most likely is the LIU (Line Interface Unit). or you might have it plugged in the wrong port on the fax itself. Make sure it's plugged into the LINE plug. If it's the LIU it would be cheaper to replace then calling for service. Unless it's under warranty still (usually 90 days)
Jan 29, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Lands Phones Logo
195 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
