Question about Xerox Office Equipment & Supplies
How do I reset waste motor error on xerox phaser 6100?
  • 3 Answers
The waste motor error usually occurs because the printer is run without the waste toner cartridge and the port where the waste toner exits is clogged. It can be a really messy job, but you can do it yourself.
Open the front cover where the waste toner cartridge is and remove the cartridge. There are two ports where the waste toner exits the printer and one or both are clogged. You will need to take the port covers off by removing the screws holding them on, but don't do both at once. In fact, before removing either, you will want to put down some paper towels to catch all the toner that you will unclog.
Remove one cover and the diaphram and tap the port with the handle of the screw driver. toner should begin coming out of the port. Cycle the printer on and you will begin to see more waste toner coming out.
You may hear a clicking noise. When you do, start tapping the port again with the screw driver. Keep doing this until no more toner comes out the port. When finished with that port, do the same on the other. It makes a huge mess, but the whole procedure takes about 15 minutes from start to cleanup.
Good luck! This fixed the problem with my 6100.
Posted on Mar 03, 2009
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
Phaser 7400 error 929
Xerox Phaser 7400 error codes 929 - Please check your Waste Toner Auger Assembly if motor won't turn and when you done the sensor test and passed the Waste Toner Auger Assembly was jammed. I just fixed this problem here, just now!
Jan 13, 2012 | Xerox Office Equipment & Supplies
XEROX Phaser 6100 service manual
We have the Phaser 6100 Service manual available at:
Jul 20, 2010 | Xerox Office Equipment & Supplies
Mac OS 10.6 Snow Leopard: Printer Driver Update for Xerox Phaser 6110 does not work ! Xerox/Apple is providing a most complicated instruction to circumvent the problem that I am not able to...
    1) Change the “Xerox” Folder Permissions:
    • Navigate to Applications > Utilities and open a Terminal window.
      • Type the following command: sudo chown -R root:admin /Library/Printers/Xerox
    • You will be prompted to enter your password.
    2) Install Rosetta from the Snow Leopard DVD:
    • Insert the Snow Leopard Install DVD
      • Select Optional Package
      • Select “Rosetta only” from the list of optional packages
      • Click install and follow instructions to complete installation; there is no need to reboot
    3) Reset Printing System:
      • Navigate to: System Preferences> Print & Fax> Xerox Phaser [6100, 6110, 6110MFP]
      • Right click on the printer
      • Select Reset Printing System
    4) Install Printer (without removing the driver):
      • Select +: add the available Xerox printer
Mar 18, 2010 | Xerox Phaser 6110 Laser Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Message waste cartridge is empty / not installed at xerox 6100
For this machine I don't think there is a reset, but it is tempormental about the light that shines throught the back of waste cartridge.
Copy and paste this link directly into your address field, and see if you have it inserted correctly and then reboot.,/?St=666,E=0000000000024654785,K=7760,Sxi=13,Solution=obj(20783)
Mar 31, 2009 | Xerox Phaser 6100/DN Laser Printer
Xerox phaser 6180n :erorr msg 1) "motor erorr" 2) "error 042-325"
Your main drive motor is either not statting or the main board is not sensing it. You can remove the covers, WITH THE MACHINE UNPLUGGED !!!!!!!!!!!!!!!! and reset all the connectors, check the drive motor, and see if maybe a gear is broken., If the machien is less than 1 year old. Call 1-800-835-6100. You will have some kind of 1 year warranty, Either on site or in depot repair, which would mean they will ship you a new machine with a box to return the one you have. If you call, make sure you have the serial number handy so it can verify the warranty.
Dec 01, 2008 | Xerox Phaser 6180N Laser Printer
Error 09,038,46: 5750
Yeah. That code means the black ink stick did not advance downward in the ink loader. Look in that area,either the block twisted or one cracked causing the block not to advance downward into the proper position. If you need to remove them and reload them, take a screw, like a drywall screw and twist it into the ink stick and remove it.
If you somehow installed an ink stick from a different model phaser printer it would have a different shape and not actuate the switch at the bottom of the loader.
Also, if your having a light stripe problem, call Xerox Phaser support at 1-800-835-6100. Have your serial number handy. You have a 1 YEAR on site repair warranty on that product. So call them if need and they will send someone to service it free of charge.
Aug 12, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
668 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
