Omega 1000 Indesit washing machine. Where can I down load a manual or handbook for this item please? Thank you
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
  • 4 Answers
SOURCE: indesit WI 121 washing machine
If this is a front loader it could be the up/down motion causing machine to vibrate against the floor. You can pick up some cushion pads for front load washer and dryers at the dealers to go under the four corners of the machines.
Posted on Dec 29, 2007
  • 3463 Answers
SOURCE: The belt from an Indesit washing machine broke a wire
The wire you refer to is an earth wire, it has probably pulled of the motor or the frame of the m/c.
If you can't see where it came from, don't worry too much, all you need to do is fasten it to a metal part of the m/c so that is is making a contact to earth.
I assume that you can get a belt o/k
Make sure that the drum and motor are free before you fit new belt.
Plz rate my solution
Posted on Dec 23, 2008
SOURCE: Trouble with Indesit WI 102 washing machine
I had trhe same problem and was going deaf!!! I know this is probably too late for your machine but it may be usefull to someone else with this model.
Originally thought the bearings had gone but had great trouble trying to source some through UK websites so decided to strip the machine. Did this by touch (no manual!) and eventually found that the bolts holding the bottom weight to the drum had all come loose (all 3!). Trying to access them to tighten was the biggest problem as the front of the machine is welded on.
Managed the above by removing the rubber door seal from the door only and tightening two of the bolts from inside the door. The third I managed to access from beneath the machine. All were tightened using 10mm socket on a bar with extension (curtain pole!) slid over the end.
During this process I had the machine on its side, removed the securing brackets, top weight + springs and wedged the drum from beneath and the side as much towards the rear of the machine as possible to aid access.
Good Luck!
Posted on Feb 22, 2009
I have an omega 1052..l am renting..please let me know what settings do the 3 knobs be on to wash only my work clothes,for approx one hour.Thank you.
Omega Product Support '
I need an Omega WD 1052 users manual. Omega Washer ... Omega Washer/DryerWD1052 ... user manual for omega ow6512wa washing machine wit. Omega .
Omega Wd1052 Instruction Manual
Omega Wd1052 Instruction Manual. esthermg71. Date: 29.09.2014, 16:28. A ll our cell are 100 brand new. _ fx-4500PA - User Manual and User Guide.
Oct 02, 2015 | Washing Machines
Lost manual can I download a new one for an Indesit Washing Machine WIXL123
If you go to the site below, you will be able to download the user instructions to your printer, or hard drive.
In the menu on the left side, click on--
Indesit user manuals
then enter your model number in the search box, and down load.the instructions.
Please leave feedback for my solution.
Jan 14, 2010 | Indesit W 123 Front Load Washer
Manual for intergrated indesit wm12x washing machine
To obtain the instructions for washer, go to,
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Jan 13, 2010 | Indesit W 123 Front Load Washer
Ive got a indesit 1000 seems like the filter is blocked but im unsure of where it is, as i put clothes in the machine but they come out dirty! please help!
Filter if this model has one down Bottom left hand side of machine , remove bottom plastic cover to see this, put down an old towel to save flooring ..good luck
Nov 19, 2009 | Indesit W 123 Front Load Washer
This online company list all Indesit WM manual:
From them:
Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
no_image_large.jpg Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
May 26, 2009 | Indesit Washing Machines
I have the solution for your query.
In your browser bar, type in ----
indesit user manuals
Click on---
manuals- user guides- handbooks- indesit service
In the search box enter your model and down load the relavent instructions.
Please leave a fixya rating if you consider my solution appropiate to your problem.
Jan 29, 2009 | Indesit W 123 Front Load Washer
Hi there where can i download an operation manual for an Indesit WIL103 washing machine thanks
In your browser bar type in---- indesit user manuals
In the drop down list click on------indesit- manuals-user guides-handbooks-indesit service
In the search box type in your model number, and down load instructions.
Plz rate my solution.
Jan 17, 2009 | Washing Machines
Indesit W1335 manual
Hi - You can download the manual from the link underlined in blue below:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 13, 2008 | Indesit W 123 Front Load Washer
Washing macine indesit wil103
i need a intrution manual for my indesit wil103 washing machine
Jul 09, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
