Question about Paradyne 6211 ADSL2+ Router (6211I1200)
Modem connects to Internet, but PC can't
I used the modem's command line to ping to www.google.com and it worked fine, so the modem is connected to the Internet. My laptop, however, can't access the Internet, even though the modem and laptop are connected with an ethernet cable. I've checked my settings and they look fine: DHCP is on, the DNS server and default gateway are 192.168.1.1, which is the address of the modem. The laptop's IP is assigned to 192.168.1.2. I can access the modem using my browser, but I can't access anything online. What could possibly be the problem? Thank you!
  • 1 more comment
  • redcurry Jul 29, 2008
    Thanks for replying. By default, the modem has the firewall enabled (the manual says it is always enabled for PPPoE, which is the connection type I have). The manual also says that, by default, all incoming IP traffic from WAN is blocked when firewall is enabled. I can, however, set up a filter to allow some IP traffic. The filter asks for the following: protocol, source IP address, source subnet mask, source port, destination IP address, destination subnet mask, and destination port. I only have to have at least one of these filled in, so should I simply type in my IP address in the destination IP address box? I can't try it right now because I'm not home. Thanks!
    By the way, all outgoing IP traffic is, by default, allowed.
  • kryses May 11, 2010
    How do I get a P2P through my routers firewall
  • 5,264 Answers
Are you using a firewall? Did you tell the firewall that the browser has permission to access the internet (go beyond the local network of the modem)?
Posted on Jul 29, 2008
Device says it's working with a 100% connection but still no Internet. Totally mystified about who to call for help, let alone what to do.
Looks like your connected to the network fine but not receiving the internet signal. Maybe your modem or router is not pushing it out. Try power cycling the modem and router for about 5 minutes (unplugging power). Try connecting to a different network if possible to rule out that its not the wireless adapter having the issue. Hope this will give you help.
Mar 08, 2011 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
My modem is hooked up to a netgear wireless router, my internet was working before but isn,t now. How can I get it to work again? It has been reset, and unplugged.
unplug the modem and the router wait 2 mins. Plug the modem in first and wait till all of the lights are solid on the modem then plug the router in. If you reset the router to the factory state chances are you are going to have to set up the routers wizard again the routers ip is 192.168.1.1 usually the default login is admin for the user and password for the password
Mar 07, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
Having trouble getting internet connection, from modem, straight to PC. using DSL Extreme.( I need Modem settings)
Assuming you have connectivity to the router, 1st click start/programs/accessories/command prompt. Command prompt will be a medium sized box that pops up.
Will look like this where you start typing:
C:\user\computers name>_
just start typing, don't hit the space bar and type exactly what I type.
ipconfig
7 lines down, there will be a line saying "DEFAULT GATEWAY. . . . . . . . . . . .192.168.1.1
The 192.168.1.1 could be different. Write it down if you can't remember it.
Open your internet browser and type this number into the url bar( this is where you would type something like http://www.google.com at) This number will get you into the DSL router. I haven't been in this router in a long time, so my memory is a little sketchy. You should be able to access the connection page and manually make a connection.
Now this all depends on weather or not you have DSL sync with modem back to the phone co. If you can get here and you have connectivity with a solid DSL light, you shoud be able to surf. Also, from the command prompt, you can test your connection to the router by typing :
ping 192.168.1.1 or what ever the default gateway is.(there's a space in between ping and the 1)
If you can ping the router anf the connection looks solid from inside the router, test from the command prompt to see if you can ping outside the network. Type ping www.google.com It should give you 3 replies from the site.
If this happens and you still can't surf, then you have firewall settings set to high or more troule shooting is needed.
Hope this helped.
Nov 30, 2010 | Efficient Networks SpeedStream 5100 Modem
No internet connection
f your modem isn't getting an answer from your ISP
  • 1 Make sure that the cable is correctly connected to both a phone line and your modem and that, if you're using an external modem, it's connected to the PC.
  • 2 Dial the access number for your Internet service provider (ISP) with a regular telephone and listen for a data tone. If you don't get one, then you have the wrong number or your ISP is down.
  • 3 If your modem is internal, skip this step. Unplug the power cord from your modem and shut down your computer. Plug the modem back in and restart your computer.
  • 4 If you have another modem cable that you can use to connect the computer to the modem, swap it with your current cable to rule out a bad cable.
  • If your connection is refused by your ISP
  • 1 Make sure your username and password are still correct. These are usually entered through a connection program that your ISP provided. You will probably have to retype your password, as you won't be able to read it on-screen.
  • 2 Locate the TCP/IP settings for your computer. In Windows, these are found in the Network and Dial-up Connection control panels. In Mac OS 9.2 and earlier, they're in the TCP/IP control panel. In Mac OS X, they're in the Network section of System Preferences.
  • 3 Check that the host name and domain name information are correctly entered in the TCP/IP settings. This information should have been supplied by your ISP.
  • If your connection is accepted but you can't load Web pages or send e-mail
  • 1 Call your ISP's support number to find out if you have been affected by a service outage.
  • 2 Unplug the power from your modem (whether it's telephone, DSL or cable) for at least 10 seconds, shut down your computer, plug the modem back in and restart your computer.
  • If your connection seems too slow
  • 1 Set your Windows computer to MS-DOS mode: Click on Start, Programs, MS-DOS Prompt.
  • 2 Type "ping" followed by an Internet domain name--for example, www.google.com or www.yahoo.com. Macintosh users with OS X can use Apple's Network Utility program to "ping." Earlier versions of Mac OS don't have it built in, but freeware programs are available on the Web.
  • 3 You should get a report saying how many milliseconds it took for your "ping" to reach the destination. A computer communicating with the Internet via a 56-KBps modem connection might typically have a 0.3-second (300-ms) or longer ping. Anything longer than 5 seconds (5,000 ms) indicates a problem with your connection that might be the fault of your ISP.
  • Read more: How to Troubleshoot an Internet Connection ' eHow.com http://www.ehow.com/how_113839_troubleshoot-internet-connection.html#ixzz15EpuN33C
    Nov 14, 2010 | Sylvania G-Netbook
    We've got the Dlink DES-1008D setup in our office. Since the past 3 weeks, we've been facing disconnection problems. 5 desktop computers, all new and very recent, are connected to this. We've got an...
    Ok, the next time when the disconnection occurs. Try the following:
    Open command prompt. And try pinging www.google.com, if the ping is successful and you are still unable to access the internet, then you may want to check the proxy settings on your web broswer, or possibly repair/reinstall the browser. You can also try accessing the internet on a different browser.
    If you are unable to ping google successfully, then try to ping the IP address of your wifi modem, this is your default gateway. If you are unable to ping this address successfully, then check the cable from the DES-1008D switch to the wifi modem. As a local area connection 'connected' just shows that the link from your PC to switch is fine.
    Please try these steps and let me know the results.
    Regards..
    Apr 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
    I have a Arris Modem and can not get on to the internet. The IT people at Bresnan took a look and found nothing wrong with the Arris. The modem is able to ping and says its online and ready to work, but...
    Do you have a cable connection kyle? i think you're using a vista operating system. Click on START, in start search bar type CMD then you'll see the command prompt as a search result. Right click and run as administrator. When you have command prompt, try to ping any website, for example www.yahoo.com. if you're able to ping yahoo that means your connected. If not do IPCONFIG, check your IP address and call your ISP, ask them if its a valid IP that they're giving out.
    Aug 29, 2009 | Arris Touchstone 450a (CM450) Modem
    Lost connection
    1. check ip address in command prompt
    2. If unable to find valid ip address , reset ipaddress , in command prompt type ipconfig /release and then ipconfig /renew
    3. Ping default gateway in command prompt
    4. then ping www.google.com in command
    5. If u can ping in command prompt issue with Internet explorer or with Operating system.
    6.Try using different browser.
    Aug 17, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
    Cannot connect although plugged in
    Check the ipaddress. Type ipconfig in command prompt. Then ping a website in command prompt if u get proper ip address e.g 10.132.147.121. Try to ping www.google.com in command prompt. If u are unable to connect. Tried to release renew Ip address.
    Type ipconfig /release then ipconfig /renew in command prompt. If you are able to ping google and still unable to connect to website using internet explorer, then issue with browser or with OS.
    No internet connection by using the ethernet cable
    Unplug the power to the modem and the USB cable. Plug in Ethernet cable in computer and plug in the modem. Wait for WAN side of the modem to connect and stabilize. If your PC is already on, you should see the network connection appear in the task bar (if it's configured to show up). Open a command prompt. Type 'ping 192.168.1.1' and press Enter. You should get 4 ping responses from the modem which indicates that you LAN connection to the modem is functional.
    Let me know if this doesn't work and I'll guide you through other methods to get it working.
    Apr 09, 2009 | Arris SURFboard SB5120 Modem
    Have internet connection but browser won't open
    try pinging google.com from the problem pc.
    1. Go to START
    2. Go to RUN
    3. Type in CMD [hit enter]
    4. IN the dos window, type : ping google.com
    5. hit enter.
    If your pc can reach google, it will ping back 4 successes
    I would install and run spybot from spybot.com. That is a spy-ware checker program and is free.
    Post back with results.
    Dec 17, 2008 | Dell Dimension 3000 PC Desktop
    Paradyne 6211 ADSL2+ Router (6211I1200) Logo
    90 people viewed this question
    Top Paradyne Computers & Internet Experts
    Michael Galve
    Michael Galve
    Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
