Question about Mitsubishi VS-50605 50" Rear Projection Television
Snowy picture My Mitsubishi VS-50603 picture is snowy on all channels. I had the cable service co. come out to check and they said it was my TV. If I run the TV thru my DVD recorder/player the picture clears up somewhat. Can you tell me what the problem might be? Thank you so much
  • 4,234 Answers
Usually a snowy picture means that you have a bad ground connection. You should see that some channels are beter than others. Verify that the cable connection is good. Try a different cable if you can. If that has no effect, than we need to start looking at the tuner itself. If you can change channels but just have a poor picture, chances are that a resolder of the tuner section will resolve the problem.
Keep us posted.
Dan
Posted on Jul 29, 2008
Cable is hooked up to my Mitsubishi vs-50603 has sound and blue screen
Blue screen of death! Not good. Check with cable co. to see if it their equiopment or yours.
Jan 04, 2015 | Mitsubishi Televison & Video
Cable company switched to digital, now my Ant A port on the vs-50603 does not receive signals. I can somewhat view the analog signals through my PIP only. other tv's in the house came back with signal 5...
When the cable company offers you digital cable, you typically need a cable box to unscramble the digital channels. Therefore you need to connect either a coaxial cable from the cable box's RF output, if it has one, or connect 3 RCA cables from the yellow, white and red jacks on the rear panel of the cable box to the TV. Analog channels only (if available) will go straight thru over the coaxial RF hookup. They are not scrambled. Select the proper input source on the TV for the cable box.
Aug 26, 2010 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS-50603 won't turn on.
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 02, 2010 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Cannot connect to cable tv
Yes, connect cable to Ant A and ensure the TV is on the input for Ant A.
Then go into the setup menu and ensure that the Input is set to Cable not Antenna.
Next, choose the auto program option to load your channels.
If you still don't get a picture and you have a small tv to bring to this outlet try this and make sure you are able to get a picture.
If you still can not get a picture then the outlet is not active and you need to call your service provider and ask them to activate the outlet for you.
Dec 29, 2009 | Mitsubishi VS-55707 TV
NO SOUND OR PICTURE JUST SNOW WAS WORKING FINE THE DAY BEFORE
Check the tv with another cable signal or another tv with that cable signal.Both check,same things happen.Ur tv digital tuner is dead.
Sep 24, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Snowy picture on certain channels and only sometimes
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Mitsubishi VS-50605 50" Rear Projection Television Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
