Question about HP Office Equipment & Supplies
Printing extremely slow, i.e.self-test report took 15 mins plus. the printer tells me that the colour cartridge is not the correct one; however it is a No. 343 which is quoted on the back of the basics guide
  • HP Master
  • 19,396 Answers
Cartridge need replacement, probably is faulty . Check print definition in printer options, set it to quick print or to a lower definition
Posted on Jul 29, 2008
    Master:
  • 555 Answers
What is the model of this HP printer?
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
Very slow operation, misleading info. re. colour cartridge
hi,
Can you please give the make and model no. of your printer
Jul 29, 2008 | Office Equipment & Supplies
Printer was working ok then error 0x610000f6 came up this comes up all the time
Follow the below mentioned steps to resolve the issue :
This error is usually due to Carriage Jam issue. 1) Power off 2) Unplug the power cable from the wall outlet (should always power off first using the power button). 3) Remove the back piece and putting it back, making sure it's well adjusted. 4) Also removed the piece where the printed paper land, and put it back. In case if this doesnt help follow the below mentioned steps : Print a self-test report : ollow these steps to print a self-test report. Press the Power button to turn the product on. Press and hold the Cancel button. Press the Red-eye Removal button. Solution one: Turn the printer off, and then turn it on Follow these steps to turn the product off and then to turn it on. Step one: Turn the printer off, and then turn it on Press the Power button to turn the product off. Wait 15 seconds. Press the Power button to turn the product on. Step two: Print a self-test report Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution two: Clear all paper jams Follow these steps to clear any paper jams. Step one: Remove any loose paper 1. Disconnect the USB cable from the product. 2. Disconnect the power cord from the back of the product. 3. Remove all unused paper from the tray. Step two: Remove all paper from inside the back of the printer. From the back of the product, remove the rear access door or duplexer, and then remove any paper stuck inside of the product. Press the tab on the left side of the rear access door to release it, and then remove the door by pulling it away from the product. Gently pull any jammed paper out of the rollers.
If your product has a duplexer :
1. Remove the duplexer from the rear of the product and remove any paper or scraps of paper stuck inside of the product. 2. Open the duplexer and remove any paper or any other obstructions. 3. Close the duplexer. 4. Reinstall the rear access door or duplexer.
Step three: Remove jammed paper from the front of the printer. Remove the paper very carefully. If the paper tears, part of it might remain inside the paper path and damage the product. Carefully remove all traces of paper that you can find. Reconnect the power cord to the back of the product. Press the Power button to turn on the product. Open the carriage access door. The carriage might try to move into the access area. If so, allow it to move to that position.
With the product turned on, disconnect the power cord from the back of the product. Unplug the power cord from the power source or electrical outlet. Check for any paper or objects that might be stopping the carriage. Reach inside the product, and then manually move the carriage. If the carriage is stuck on the right side of the product , move the carriage to the left side of the product. If the carriage is stuck on the left side of the product , move the carriage to the right side of the product. If the carriage is stuck in the middle of the product , move the carriage to the right side of the product. Remove any loose paper or obstructions found. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Close the carriage access door. Reconnect the power cord to the product and to the power source. Reconnect the USB cable to the product. Load plain paper in the tray. Press the Power button to turn the product on. Step four: Print a self-test report If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution three: Make sure that the cartridges are installed correctly Improper placement or installation of the cartridges can cause a carriage jam. Installing only one cartridge can also cause a carriage jam. Follow these steps to make sure that the cartridges are installed correctly: Step one: Remove the cartridges Press the Power button to turn on the product. Open the carriage access door. Press the tab on one cartridge to release it and then remove it from the slot. Repeat the previous steps to remove the other cartridges. Look under and around the carriage, and then remove any obstructions. Step two: Reinstall the cartridges 1 - Latch in down position Slide one cartridge into its slot with the matching icon, and then press it in until it snaps into place. Figure 9: Slide one cartridge into its slot and snap it into place
Repeat the previous steps to install the other cartridges. Close the carriage access door. Load plain paper in the tray. Figure 10: Load plain paper Step three: Print a self-test report Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution four: Connect the printer directly to a wall outlet If the product is connected to a power strip or a surge protector, follow these steps to connect the product directly to a wall outlet. Step one: Connect the printer directly into a wall outlet Press the Power button to turn off the product. Disconnect the power cord from the back of the product. Disconnect the power cord from the power device. Plug the power cord directly into a wall outlet. Connect the power cord to the back of the product. Press the Power button to turn on the product. Try to print.
Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution five: Perform a power reset. Follow these steps to reset the product. Step one: Perform a power reset Press the Power button to turn on the product. With the product turned on, disconnect the power cord from back of the product. Disconnect the power cord from the wall outlet. Wait at least 15 seconds. Connect the power cord into wall outlet. Connect the power cord to the back of the product. If the product does not turn on by itself, press the Power button ( ) to turn it on. Try to print. Step two: Print a self-test report. Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. If the self-test prints, then your carriage jam issue is resolved. Connect the USB cable to continue the print job. Step three: Search for more information If you detect another issue, go to the HP Product Support Home Page, and then search for another document that relates to the issue you are experiencing. Solution six: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product.
May 01, 2011 | HP Office Equipment & Supplies
My HP 5610 is printing extremely slow.
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides..
Oct 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Photo printing
Try printing a manual self-test page:
1. Press and hold Cancel on the control panel.
2. While holding Cancel, press Start Copy Color.
This report provides useful information about your print cartridges, including status information. If the self-test report shows a problem, clean the print cartridges.
Feb 10, 2008 | HP Photosmart C3180 All-In-One InkJet...
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 2410 very slow printing issue
It is a cartridge problem. Solution for my hp 3645 (I have the same story as bb18, but different printer) was to remove color cartridge!
The printer is fast now, of course it does not print in color :) (I`m waiting for a new color cartridge) Good luck,
Marcin
Dec 26, 2007 | HP PSC 2410 All-In-One InkJet Printer
Printer problem with 6210 all in one.
Try to print a self test page from the printer itself, do these:
  1. Press and hold the Cancel and the Color buttons at the same time.
  2. Release both buttons.
  3. The Self Test Report will be printed.
and check if it is the same output, if yes then follow the steps below:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
  2. Verify that there is plain white paper in the Input tray.
  3. Press Setup .
  4. Press c00712200.gif or c00712201.gif to select Tools and then press OK .
  5. Press c00712200.gif or c00712201.gif to select Clean Print Cartridge and then press OK . The unit prints a test page.
  6. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  1. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  2. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
  3. Open HP Solution Center .
  4. Click Settings .
  5. Click Print Settings .
  6. Click Printer Toolbox .
  7. Click the Estimated Ink Levels tab
  • Replace any ink cartridge that is low on ink.
  • If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them.
  • With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
  • Allow the cartridges to dry before reinserting them.
  • Close the unit, and plug the power cord back in.
  • Print a self-test page to check the results. Follow the steps below to print a self-test page.
    1. Press Setup .
    2. Press c00712200.gif or c00712201.gif until Print Report displays and then press OK .
    3. Press c00712200.gif or c00712201.gif until Self-Test Report displays and then press OK . The self-test report prints.
    If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
    IF THE SELF TEST REPORT IS CLEAN, THEN TRY TO PRINT FROM ANOTHER SOFTWARE LIKE PAINT, NOTEPAD AND IF THE OUTPUT IS OK THEN THE PROBLEM IS ON THE SOFTWARE THAT YOU ARE USING
    Dec 19, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    Slow Printing
    Hi, The slow printing issue can occure even if the cartridges are out or low in ink try to check the print function by the stand alone unit by printing a self test page Here are the steps to print a self test page: On the front panel of the product, press Menu (or Setup) . Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK . Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK . If the self test page takes less time to print and if all the color blocks and black block print fine the ink level are fine. if the time for self test is also more try to clean the cartridge contacts and replace the cartridges if needed this will fix the issue. If the printer works fine as stand alone self test and copy try to performe the steps in the below webpage: ========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093466&lc=en&cc=us&dlc=en&product=2512010&rule=10185&lang=en ========== If the issue is still un fixed try to set the print directly settings in the printer properties Click on start >> control panel >> printer and faxes >> there look for the HP printer icon with the check mark and right click on it and select properties and then click on advance tab and under it select the print directly to printer and click on apply and ok to save the settings. Once done try to print and check with the issue. Hope this will fix the issue. Regards, Barret.
    Sep 03, 2007 | HP PSC 2175 All-In-One InkJet Printer
    26 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
