Question about Canon EOS 40D Digital Camera
Remote Firing of Flash Units
I am trying to fire some remote flash units with my 40D however I cant fire them with the main camera flash or my Speedlight off..? Is it possible in settings to manage this on the camera..or do I need to use the remote cable that is supplied with the flash units..? Hope this makes sense...thanks Paul
    Scholar:
  • 54 Answers
The EOS 40D does not have a transmitter built in. The remote flash units must be set to "Slave" and the on-camera external flash unit (eg Speedlite 580EX) or transmitter (ST-E2) set to "Master". Note that the Speedlite 430EX doesn't have the function to act as Master and you need a minimum or the 580EX or a ST-E2 speedlite transmitter (or similar) as Master/s.
Posted on Apr 16, 2010
Useing a flash off a sony a300
Obviously, you'd need a separate flash unit, since you can't take the built-in flash off the camera. Just as obviously, you'd need a way to trigger that flash.
Some flash units have a remote sensor that will respond to the camera's flash. The a300 has a wireless mode for triggering such flashes. There are remote flash systems that include a radio transmitter that fits onto the camera's hot shoe and a receiver that the flash mounts onto. Some flash units have a jack so you can use a cord to connect the flash to the camera.
The degree of automation depends on the system. The a300's wireless mode works best with Sony's own flash units. The separate wireless and cord methods will work with just about any flash, though you'll probably have to set the exposure and flash output yourself.
Jan 14, 2013 | Sony Alpha DSLR-A300 Digital Camera
Using a Sunpak 555 with Cybersync transmitters with a canon 40D off camera and getting inconsistent firing
did you find a solution? ive experienced a similiar problem. i think i might need to buy new flashes.
Aug 13, 2012 | Sunpak Auto 555 TTL Flash
I have a Canon EOS 40D camera. We are having problems with using an external flash. The pictures always come out extremely dark with the external flash. The flash seems to work fine, it flashes...
I don't know if this will help and this post is two months old. The camera store may be right that the synchronization is the issue which tends me to point a finger at the external flash. There are at least three different flash units that will flash when the picture is made but only one type will sync with the camera. A digital flash unit is different from a film flash so a Canon EX type is required to sync with Canon TTL or TTL II digital cameras. An EZ will flash but it's off a bit, so I can only assume that your Promaster and Canon flash units are for film cameras. Okay and another thing that could be throwing things off a bit is the camera may have been programed in Custom Functions to use "Second Curtain" or "Rear Curtain". Just seams to me if the built in flash works then it's the external units at fault.
Oct 17, 2010 | Canon EOS 40D Digital Camera
The 580EX is firing but images comes out completely dark it just started happening in a session around 2 hours ago........i put it on another camera the 40d still the same problem what can this be?
When the flash mode TTL. Then this situation can occur if the proximity is working with other studio flash light traps. Your work makes flash another flash while TTL metering. And when is your main flash another flash did not have time to recharge.
Sep 18, 2010 | Canon SPEEDLITE 580EX TTL Flash
Intermittant flash firing.
The main cpu is bad and you need to send it back to the factory.
Nov 27, 2008 | Nikon Speedlight SB-600 TTL Flash
Basic info needed Where do the Batteries Go? etc What do the settings all mean?
Your manual is here
http://gdlp01.c-wss.com/gds/6/0900008236/01/EOS40D_HG_EN.pdf
canon eos 40d manual Google Search
ISO settings are basically the way the camera responds to light. The higher the ISO, the more the camera will take low light images. The trade off though in higher ISO is that you get grain.
You can use any infra red or Bluetooth flash unit, but make sire you get on that lists your particular model. That way they actually work from the amount of light that hits the CMOS sensor inside the camera itself.
Flash units. Take a Look at Metz, they are the brand leader.
canon eos 40d remote flash Google Search
and this one
Amazon com Yongnuo RF603CII RF603II Remote Flash Trigger for Canon EOS 10D...
Aug 29, 2017 | Sunpak 2000DZ Flash
TTL Multi-Flash Sync Cord SC-27
YES YOU CAN BUT WHY NOT SET THE CAMERA IN THRE ITTL COMMANDER MODE
AND SHOOT THE FLASHES IN SETTING 4A
NO CORDS NEEDED THEN .
BERRIE SMITH CAMERA REPAIR
BBMW@BELLSOUTH.NET
Sep 19, 2008 | Nikon Speedlight SB-800 TTL Flash
Sunpak Auto zoom 3000 thyristor
You can use the Sunpak on a bracket with a "slave trigger" and fire the slave with the Nikon's pop-up flash. I do the same with a SunPak 3600 Auto Zoom. Just remember not to have the red-eye feature operating. Those little slave triggers are only a couple of dollars and I already had few brackets.
Jun 03, 2008 | Cameras
Flash not working
The flash circuit needs to be replaced. you can get a used one for around 20.00 off ebay. I have a few of them from salvaged units.
Apr 18, 2008 | Kodak EasyShare Z650 Digital Camera
LCD moniter locking up on SB800
I would pack it back in to the box with a detailed description and send the flash back!
Jerry G.
Mar 30, 2008 | Nikon Speedlight SB-800 TTL Flash
Canon EOS 40D Digital Camera Logo
172 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
