Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA wont power
I have the same issue do you have images where to find that transistor? or any other tips you could help me with getting this resolved
Jim
  • RCA Master
  • 8,617 Answers
Which transistor are you trying to find for your RCa? Also whats the symptoms?
Posted on Jul 31, 2008
Clicking noise when plugged in. wont power on
Scott, sounds like it could be a power supply issue,
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
TV Will Not Turn On Troubleshooting Help for Finding Problems for Your TV...
RCA Television
https://ca.answers.yahoo.com/question/index?qid=20071128221851AAYLBhg
Mar 19, 2016 | RCA CA 32" Cla 720p 60Hz LED TV LED32C33RQ...
20 inch rca colortrak plus wont turn on.trying to figure out where power relay is on board. any help would be greatly appreciated thanks kris
Dear Kris
You check the out put voltage of SMPS
If OK then check the Horz. out put Transistor / MOSFET
Check the Horz. driver TR.
Apr 28, 2011 | RCA 20" TV
Power wont come on
basically power regulator is defective for that situation... check also horizontal output ( transistor near flyback)
May 09, 2010 | RCA L42WD22 42 in. LCD Television
I have a 52in rca it wont power up no sound just
FBT flybck Tranfomer 239111 Call Mats 1-800-628-1118 Ck hori output Transistor in case it is shorted.
Dec 21, 2009 | RCA P52926 52" Rear Projection Television
No image when switched on
are you plugged in with hdmi or rca (red white yellow) if you hold down the power button til it flashes a bunch then it resets the PS3 to default rca connection you then have to plug in the rca cables that came with the ps3 adjust the setting with both rca and hdmi pluged in then unplug the rca.
Oct 23, 2009 | Sony Playstation 3 (PS3) Console
3d image
This is what known as a convergence problem. First question is in your setup menu do you have a convergence option.. if you do then do you have any control in that mode does the crosshars move up and down and side to side... if you dont then you have a convergence power supply issue.. if you do it could be a setup issue. IF you do not have convergence in your setup menu then it possiblely be a special fuse.. and bad electrical connections. so let me know and ill see if we can narrow it down further
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on
The green light indicates that it is getting power from the outlet ok.
The clicking is the power relay trying to turn it on but there is an internal fault forcing it to shutdown. You either have a power supply problem, horizontal output transistor (HOT) is shorted or a bad flyback transformer. In any case it can most likely be repaired by a qualified technitian. If it is the flyback it may be expensive.
Mar 10, 2008 | RCA F32650 32" TV
RCA Scenium HD52W140 Won't power
This has happened to me twice. We had the warranty and thank God we did. The problem is in a $7 transistor and you probably need to call a repair shop. They worked on ours and it took about 20 minutes to replace the transistor. They take out the bad one and soder in the new one on the circut board inside the back of the tv. The total cost was nothing for us because of the warranty, but it came to $385 for labor and stuff. Again, this happened twice, one year to the date from one another. The repair guy finally installed a different brand of transistors and it's been fine since. He said that RCA makes some terrible transistors and he will not use them again. Try and get the repair person to use a non-rca brand transistor, because it will more than likely happen again if he don't.
Dec 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Guide Plus Gold Gemstar
The set tries 3 times to come on (3 blinks) if there a problem such as a short, it will cycle without turning on. Unfortunately your set is notorious for having bad flyback transformers. Most likely the horizontal output transistor is shorted as well. Common causes for your symptom are: LL05 (horiz out transformer) RCA part# 257805; TL 02 ( horiz output transistor) 2SC5148; and open connections on the printed circuit board at LL 04 and L14401 (coils) all of which can cause the horizontal output transistor to be shorted.
0
Nov 25, 2007 | RCA F32450 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
