Question about Ovens
Whirlpool Gas Oven Model SF377PEGQ 0
Hi, thinking about replacing the bake igniter assembly on my super capacity 465. Everything seems to work fine with the exception of the oven itself. Based on forums I have read, the igniter assembly might be the answer. Question - does replacing this part also control the release of gas in the oven as well? At the present time I hear nothing in the form of gas flow when I try to run the oven itself.
Thanks
applianceboy
  • 77 Answers
SOURCE: ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
check the operation of the micro switches on the lock motor. that they are open when they should be and closed when they should be. often they need to be cleaned or replaced. if this doesnt help re post there is some board work to do, i would suggest a tech do this part though. always unplug range when you work on them! good luck.
Posted on Sep 28, 2007
SOURCE: WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Posted on Sep 28, 2008
SOURCE: Whirlpool self cleaning oven, Super capacity 465, door will not close
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
Posted on Dec 02, 2008
meBNme
  • 334 Answers
SOURCE: wHIRLPOOL SUPER CAPACITY 465 MODEL: SF368LEPQ GAS SMELL
I will rarely say "call a professional" here because this is a do it yourself site right?
However, in this case, you obviously have a gas leak and/or malfunctioning gas valve.
Unless you have experience and training in detecting gas leaks I highly recommend shutting the gas off to the unit, ventilating the area, and calling a pro.
Gas can be very dangerous if handled improperly and a mere spark can "make house go kaboom".
If you are smelling it strong enough that you have to open windows, it is a potentially dangerous situation.
Posted on Dec 06, 2008
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Posted on Feb 25, 2009
I have a Whirlpool Super Capacity 465 and am having issues with the following. Sometimes while baking, the oven turns off and the power to the appliance stays on, sometimes everything shuts off and PF
PF stands for power failure you are loosing incoming power power check the terminal block the control will do goofey thing with loss of voltage rule of thumb no more than a 10% voltage loss 108VAC minuim
Aug 04, 2014 | Whirlpool Ovens
Whirlpool super capacity 465
You may have several things going on f1 e4 is a control board issue with the touch panel plug in into the control board disconnect and reconnect if this problem presist will need a control board and touch pad for the oven not staying lit there is a new oven igniter kit 8190618 unfortunately no good diagnostics for this problem good luck
Feb 18, 2014 | Ovens
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 | Ovens
I have a Whirlpool Super Capacity 465 oven Model# SF315PEG. The bake valve was being energized but not opening to allow gas into the burner. Bought a new valve assembly P/N 3195008 and replaced. Problem...
The ignitor is not allowing enough 'current flow' to open the valve. The ignitor , even if it glows, can be 'low current' to valve.
(the ignitor current controls valve)
Sep 03, 2009 | Ovens
Feb 25, 2009 | Ovens
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool Accubake oven super capacity series 465
In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
Mar 16, 2008 | Whirlpool SB160PEE Gas Single Oven
Ovens Logo
75 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
